Retrieves snapmirror policies of type "mirror-vault", "sync-mirror" and "strict-sync-mirror"
example
the following example shows how to retrieve a collection of snapmirror policies <br/>
get "/api/storage/snapmirror/policies"
<br/>
# learn more
* [doc /snapmirror/policies](#docs-snapmirror-snapmirror_policies)
GET /snapmirror/policies
Retrieves SnapMirror policies of type "mirror-vault", "sync-mirror" and "strict-sync-mirror".
Related ONTAP commands
snapmirror policy show
Example
The following example shows how to retrieve a collection of SnapMirror policies.
GET "/api/storage/snapmirror/policies"
Learn more
sync_type |
string |
query |
False |
Filter by sync_type |
uuid |
string |
query |
False |
Filter by uuid |
network_compression_enabled |
boolean |
query |
False |
Filter by network_compression_enabled |
scope |
string |
query |
False |
Filter by scope |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
comment |
string |
query |
False |
Filter by comment |
identity_preservation |
string |
query |
False |
Filter by identity_preservation |
sync_common_snapshot_schedule.name |
string |
query |
False |
Filter by sync_common_snapshot_schedule.name |
sync_common_snapshot_schedule.uuid |
string |
query |
False |
Filter by sync_common_snapshot_schedule.uuid |
transfer_schedule.name |
string |
query |
False |
Filter by transfer_schedule.name |
transfer_schedule.uuid |
string |
query |
False |
Filter by transfer_schedule.uuid |
throttle |
integer |
query |
False |
Filter by throttle |
name |
string |
query |
False |
Filter by name |
type |
string |
query |
False |
Filter by type |
retention.label |
string |
query |
False |
Filter by retention.label |
retention.count |
integer |
query |
False |
Filter by retention.count |
retention.prefix |
string |
query |
False |
Filter by retention.prefix |
retention.creation_schedule.name |
string |
query |
False |
Filter by retention.creation_schedule.name |
retention.creation_schedule.uuid |
string |
query |
False |
Filter by retention.creation_schedule.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[snapmirror_policy] |
"next": {
"href": "/api/resourcelink"
"records": [
"comment": "string",
"identity_preservation": "string",
"name": "MirrorAndVault",
"retention": [
"count": 7,
"creation_schedule": {
"name": "weekly",
"label": "hourly",
"prefix": "string"
"scope": "string",
"svm": {
"name": "svm1",
"sync_common_snapshot_schedule": {
"name": "weekly",
"sync_type": "string",
"throttle": 0,
"transfer_schedule": {
"name": "weekly",
"type": "string",
Status: Default
ONTAP Error Response codes
| Error code | Description |
13303842 |
Invalid SnapMirror policy type. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
creation_schedule
Schedule used to create Snapshot copies on the destination for long term retention.
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
snapmirror_policy_rule
SnapMirror policy rule for retention.
count |
integer |
Number of Snapshot copies to be kept for retention. |
creation_schedule |
Schedule used to create Snapshot copies on the destination for long term retention. |
label |
string |
Snapshot copy label |
prefix |
string |
Specifies the prefix for the Snapshot copy name to be created as per the schedule. If no value is specified, then the label is used as the prefix. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
Schedule used to create common Snapshot copies for synchronous relationships.
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
transfer_schedule
The schedule used to update asynchronous relationships.
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
snapmirror_policy
SnapMirror policy information
_links |
comment |
string |
Comment associated with the policy. |
string |
Specifies which configuration of the source SVM is replicated to destination. This field is applicable only for SVM data protection and async policies. |
name |
string |
boolean |
Specifies whether network compression is enabled for transfers. This is applicable only to async policies. |
retention |
array[snapmirror_policy_rule] |
Policy on Snapshot copy retention. This is applicable only to async policies. |
scope |
string |
Set to "svm" for policies owned by an SVM, otherwise set to "cluster". |
svm |
sync_common_snapshot_schedule |
Schedule used to create common Snapshot copies for synchronous relationships. |
sync_type |
string |
throttle |
integer |
Throttle in KB/s. Default to unlimited. |
transfer_schedule |
The schedule used to update asynchronous relationships. |
type |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
