Retrieves the collection of aggregates for the entire cluster
spaceblock_storageinactive_user_data -
spacefootprint# related ontap commands -
storage aggregate show
learn more
doc /storage/aggregates](#docs-storage-storage_aggregates)
GET /storage/aggregates
Retrieves the collection of aggregates for the entire cluster.
Expensive properties
There is an added cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query parameter. See DOC Requesting specific fields to learn more.
space.block_storage.inactive_user_data -
space.footprint
Related ONTAP commands
Learn more
recommend |
boolean |
query |
False |
If set to 'true', it queries the system for the recommended optimal layout for creating new aggregates. The default setting is 'false'. |
show_spares |
boolean |
query |
False |
If set to 'true', the spares object is returned instead of records to show the spare groups in the cluster. The default setting is 'false'. |
name |
string |
query |
False |
Filter by name |
data_encryption.drive_protection_enabled |
boolean |
query |
False |
Filter by data_encryption.drive_protection_enabled |
data_encryption.software_encryption_enabled |
boolean |
query |
False |
Filter by data_encryption.software_encryption_enabled |
create_time |
string |
query |
False |
Filter by create_time |
snaplock_type |
string |
query |
False |
Filter by snaplock_type |
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
uuid |
string |
query |
False |
Filter by uuid |
block_storage.plexes.name |
string |
query |
False |
Filter by block_storage.plexes.name |
block_storage.hybrid_cache.disk_count |
integer |
query |
False |
Filter by block_storage.hybrid_cache.disk_count |
block_storage.hybrid_cache.enabled |
boolean |
query |
False |
Filter by block_storage.hybrid_cache.enabled |
block_storage.hybrid_cache.used |
integer |
query |
False |
Filter by block_storage.hybrid_cache.used |
block_storage.hybrid_cache.size |
integer |
query |
False |
Filter by block_storage.hybrid_cache.size |
block_storage.hybrid_cache.raid_type |
string |
query |
False |
Filter by block_storage.hybrid_cache.raid_type |
block_storage.primary.disk_class |
string |
query |
False |
Filter by block_storage.primary.disk_class |
block_storage.primary.raid_type |
string |
query |
False |
Filter by block_storage.primary.raid_type |
block_storage.primary.checksum_style |
string |
query |
False |
Filter by block_storage.primary.checksum_style |
block_storage.primary.disk_count |
integer |
query |
False |
Filter by block_storage.primary.disk_count |
block_storage.primary.raid_size |
integer |
query |
False |
Filter by block_storage.primary.raid_size |
block_storage.mirror.state |
string |
query |
False |
Filter by block_storage.mirror.state |
block_storage.mirror.enabled |
boolean |
query |
False |
Filter by block_storage.mirror.enabled |
state |
string |
query |
False |
Filter by state |
home_node.name |
string |
query |
False |
Filter by home_node.name |
home_node.uuid |
string |
query |
False |
Filter by home_node.uuid |
space.efficiency_without_snapshots.ratio |
number |
query |
False |
Filter by space.efficiency_without_snapshots.ratio |
space.efficiency_without_snapshots.savings |
integer |
query |
False |
Filter by space.efficiency_without_snapshots.savings |
space.efficiency_without_snapshots.logical_used |
integer |
query |
False |
Filter by space.efficiency_without_snapshots.logical_used |
space.footprint |
integer |
query |
False |
Filter by space.footprint |
space.block_storage.available |
integer |
query |
False |
Filter by space.block_storage.available |
space.block_storage.size |
integer |
query |
False |
Filter by space.block_storage.size |
space.block_storage.inactive_user_data |
integer |
query |
False |
Filter by space.block_storage.inactive_user_data |
space.block_storage.full_threshold_percent |
integer |
query |
False |
Filter by space.block_storage.full_threshold_percent |
space.block_storage.used |
integer |
query |
False |
Filter by space.block_storage.used |
space.efficiency.ratio |
number |
query |
False |
Filter by space.efficiency.ratio |
space.efficiency.savings |
integer |
query |
False |
Filter by space.efficiency.savings |
space.efficiency.logical_used |
integer |
query |
False |
Filter by space.efficiency.logical_used |
space.cloud_storage.used |
integer |
query |
False |
Filter by space.cloud_storage.used |
dr_home_node.name |
string |
query |
False |
Filter by dr_home_node.name |
dr_home_node.uuid |
string |
query |
False |
Filter by dr_home_node.uuid |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
error |
num_records |
integer |
Number of records |
records |
array[aggregate] |
spares |
array[aggregate_spare] |
"next": {
"href": "/api/resourcelink"
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
"records": [
"block_storage": {
"hybrid_cache": {
"disk_count": 6,
"raid_type": "string",
"size": 1612709888,
"used": 26501122
"mirror": {
"enabled": "",
"state": "string"
"plexes": [
"name": "plex0"
"primary": {
"checksum_style": "string",
"disk_class": "performance",
"disk_count": 8,
"raid_size": 16,
"cloud_storage": {
"stores": [
"cloud_store": {
"name": "store1",
"used": 0
"create_time": "2018-01-01 12:00:00 -0400",
"dr_home_node": {
"name": "node1",
"home_node": {
"name": "node1",
"name": "node1_aggr_1",
"node": {
"name": "node1",
"snaplock_type": "string",
"space": {
"block_storage": {
"available": 10156560384,
"full_threshold_percent": 0,
"inactive_user_data": 304448,
"size": 10156769280,
"used": 2088960
"cloud_storage": {
"used": 402743264
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"efficiency_without_snapshots": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"footprint": 608896
"state": "string",
"uuid": "string"
"spares": [
"disk_class": "solid_state",
"layout_requirements": [
"aggregate_min_disks": 6,
"raid_group": {
"default": 16,
"max": 28,
"min": 5
"node": {
"name": "node1",
"syncmirror_pool": "string",
"usable": 9
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
19726382 |
Another provisioning operation is in progress on this cluster. Wait a few minutes, and try the operation again. |
19726344 |
No recommendation can be made for this cluster. |
19726357 |
Aggregate recommendations are not supported on MetroCluster. |
19726358 |
Aggregate recommendations are not supported on ONTAP Cloud. |
19726359 |
Aggregate recommendations are not supported on ONTAP Select. |
19726341 |
Not enough eligible spare disks are available on the node. |
787092 |
The target field cannot be specified for this operation. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
_links
self |
hybrid_cache
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs.
disk_count |
integer |
Number of disks used in the cache tier of the aggregate. Only provided when hybrid_cache.enabled is 'true'. |
enabled |
boolean |
Aggregate uses HDDs with SSDs as a cache |
raid_type |
string |
RAID type for SSD cache of the aggregate. Only provided when hybrid_cache.enabled is 'true'. |
size |
integer |
Total usable space in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'. |
used |
integer |
Space used in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'. |
mirror
enabled |
boolean |
Aggregate is SyncMirror protected |
state |
string |
plex_reference
Plex
_links |
name |
string |
primary
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details.
checksum_style |
string |
The checksum style used by the aggregate. |
disk_class |
string |
The class of disks being used by the aggregate. |
disk_count |
integer |
Number of disks used in the aggregate. This includes parity disks, but excludes disks in the hybrid cache. |
raid_size |
integer |
Option to specify the maximum number of disks that can be included in a RAID group. |
raid_type |
string |
RAID type of the aggregate. |
block_storage
Configuration information for the locally attached portion of the aggregate. When a cloud store is also used by this aggregate, this is referred to as the performance tier.
hybrid_cache |
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs. |
mirror |
plexes |
array[plex_reference] |
Plex reference for each plex in the aggregate. |
primary |
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details. |
cloud_store
Cloud store
_links |
name |
string |
uuid |
string |
cloud_storage_tier
cloud_store |
Cloud store |
used |
integer |
Capacity used in bytes in the cloud store by this aggregate. This is a cached value calculated every 5 minutes. |
cloud_storage
Configuration information for the cloud storage portion of the aggregate. This is referred to as the capacity tier.
attach_eligible |
boolean |
Aggregate is eligible for a cloud store to be attached. |
stores |
array[cloud_storage_tier] |
Configuration information for each cloud storage portion of the aggregate. |
tiering_fullness_threshold |
integer |
The percentage of space in the performance tier that must be used before data is tiered out to the cloud store. Only valid for PATCH operations. |
data_encryption
boolean |
Aggregate uses self-encrypting drives with data protection enabled. |
boolean |
NetApp Aggregate Encryption enabled. All data in the aggregate is encrypted. |
dr_home_node
Node where the aggregate belongs after disaster recovery. The value for this field might differ from the 'node' field during switchover.
name |
string |
uuid |
string |
home_node
Node where the aggregate belongs after giveback. The value for this field might differ from the value of the 'node' field during takeover.
_links |
name |
string |
uuid |
string |
node
Node where the aggregate currently resides.
_links |
name |
string |
uuid |
string |
block_storage
available |
integer |
Space available in bytes |
integer |
The aggregate used percentage at which 'monitor.volume.full' EMS is generated. |
integer |
The size that is physically used in the block storage and has a cold temperature, in bytes. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data or **. |
size |
integer |
Total usable space in bytes, not including WAFL reserve and aggregate Snapshot copy reserve. |
used |
integer |
Space used or reserved in bytes. Includes volume guarantees and aggregate metadata. |
cloud_storage
used |
integer |
Used space in bytes in the cloud store. Only applicable for aggregate with a cloud store tier. |
efficiency
Storage efficiency
logical_used |
integer |
Logical used |
ratio |
number |
Data reduction ratio (logical_used / used) |
savings |
integer |
Space saved by storage efficiencies (logical_used - used) |
Storage efficiency that does not include the savings provided by Snapshot copies
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
space
block_storage |
cloud_storage |
efficiency |
Storage efficiency |
efficiency_without_snapshots |
Storage efficiency that does not include the savings provided by Snapshot copies |
footprint |
integer |
A summation of volume footprints (including volume guarantees), in bytes. This includes all of the volume footprints in the block_storage tier and the cloud_storage tier. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
aggregate
_links |
block_storage |
Configuration information for the locally attached portion of the aggregate. When a cloud store is also used by this aggregate, this is referred to as the performance tier. |
cloud_storage |
Configuration information for the cloud storage portion of the aggregate. This is referred to as the capacity tier. |
create_time |
string |
Timestamp of aggregate creation |
data_encryption |
dr_home_node |
Node where the aggregate belongs after disaster recovery. The value for this field might differ from the 'node' field during switchover. |
home_node |
Node where the aggregate belongs after giveback. The value for this field might differ from the value of the 'node' field during takeover. |
name |
string |
Aggregate name |
node |
Node where the aggregate currently resides. |
snaplock_type |
string |
SnapLock type |
space |
state |
string |
Operational state of the aggregate |
uuid |
string |
Aggregate UUID |
raid_group
default |
integer |
Default number of disks in a RAID group |
max |
integer |
Maximum number of disks allowed in a RAID group |
min |
integer |
Minimum number of disks allowed in a RAID group |
layout_requirement
aggregate_min_disks |
integer |
Minimum number of disks to create an aggregate |
default |
boolean |
Indicates if this RAID type is the default |
raid_group |
raid_type |
string |
RAID type |
node
Node where the spares are assigned
_links |
name |
string |
uuid |
string |
aggregate_spare
checksum_style |
string |
The checksum type that has been assigned to the spares |
disk_class |
string |
Disk class of spares |
layout_requirements |
array[layout_requirement] |
Available RAID protections and their restrictions |
node |
Node where the spares are assigned |
size |
integer |
Usable size of each spare in bytes |
syncmirror_pool |
string |
SyncMirror spare pool |
usable |
integer |
Total number of usable spares |
