Retrieve a collection of disks
GET /storage/disks
Retrieves a collection of disks.
Related ONTAP commands
storage disk show
Learn more
node.name |
string |
query |
False |
Filter by node.name |
node.uuid |
string |
query |
False |
Filter by node.uuid |
bay |
string |
query |
False |
Filter by bay |
vendor |
string |
query |
False |
Filter by vendor |
dr_node.uuid |
string |
query |
False |
Filter by dr_node.uuid |
dr_node.name |
string |
query |
False |
Filter by dr_node.name |
rpm |
integer |
query |
False |
Filter by rpm |
serial_number |
string |
query |
False |
Filter by serial_number |
shelf.uid |
string |
query |
False |
Filter by shelf.uid |
pool |
string |
query |
False |
Filter by pool |
usable_size |
integer |
query |
False |
Filter by usable_size |
home_node.name |
string |
query |
False |
Filter by home_node.name |
home_node.uuid |
string |
query |
False |
Filter by home_node.uuid |
model |
string |
query |
False |
Filter by model |
aggregates.uuid |
string |
query |
False |
Filter by aggregates.uuid |
aggregates.name |
string |
query |
False |
Filter by aggregates.name |
type |
string |
query |
False |
Filter by type |
state |
string |
query |
False |
Filter by state |
name |
string |
query |
False |
Filter by name |
rated_life_used_percent |
integer |
query |
False |
Filter by rated_life_used_percent |
firmware_version |
string |
query |
False |
Filter by firmware_version |
uid |
string |
query |
False |
Filter by uid |
class |
string |
query |
False |
Filter by class |
drawer.slot |
integer |
query |
False |
Filter by drawer.slot |
drawer.id |
integer |
query |
False |
Filter by drawer.id |
container_type |
string |
query |
False |
Filter by container_type |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[disk] |
"next": {
"href": "/api/resourcelink"
"records": [
"aggregates": [
"name": "aggr1",
"bay": 1,
"class": "solid_state",
"container_type": "spare",
"dr_node": {
"name": "node1",
"firmware_version": "NA51",
"home_node": {
"name": "node1",
"model": "X421_HCOBE450A10",
"name": "1.0.1",
"node": {
"name": "node1",
"pool": "pool0",
"rated_life_used_percent": 10,
"rpm": 15000,
"serial_number": "KHG2VX8R",
"shelf": {
"uid": 7777841915827391056
"state": "present",
"type": "ssd",
"uid": "002538E5:71B00B2F:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000",
"usable_size": 959934889984,
"vendor": "NETAPP"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
dr_node
name |
string |
uuid |
string |
drawer
id |
integer |
slot |
integer |
home_node
_links |
name |
string |
uuid |
string |
node
_links |
name |
string |
uuid |
string |
shelf_reference
Shelf
_links |
uid |
string |
disk
aggregates |
array[aggregates] |
List of aggregates sharing this disk |
bay |
string |
Disk shelf bay |
class |
string |
Disk class |
container_type |
string |
Type of overlying disk container |
dr_node |
drawer |
firmware_version |
string |
home_node |
model |
string |
name |
string |
Cluster-wide disk name |
node |
pool |
string |
Pool to which disk is assigned |
integer |
Percentage of rated life used |
rpm |
integer |
Revolutions per minute |
serial_number |
string |
shelf |
Shelf |
state |
string |
State |
type |
string |
Disk interface type |
uid |
string |
The unique identifier for a disk |
usable_size |
integer |
vendor |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
