REST API reference
Retrieves a collection of snapshot copy policies
learn more
  • [doc /storage/snapshot-policies](#docs-storage-storage_snapshot-policies)
GET /storage/snapshot-policies
Retrieves a collection of Snapshot copy policies.
  • snapshot policy show
enabled
boolean
query
False
Filter by enabled
copies.snapmirror_label
string
query
False
Filter by copies.snapmirror_label
copies.prefix
string
query
False
Filter by copies.prefix
copies.schedule.name
string
query
False
Filter by copies.schedule.name
copies.count
integer
query
False
Filter by copies.count
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
scope
string
query
False
Filter by scope
uuid
string
query
False
Filter by uuid
comment
string
query
False
Filter by comment
name
string
query
False
Filter by name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
return_timeout
integer
query
False
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[snapshot_policy]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "comment": "string",
      "copies": [
          "prefix": "string",
          "schedule": {
            "name": "hourly"
          "snapmirror_label": "string"
      "enabled": 1,
      "name": "default",
      "scope": "string",
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
schedule
name
string
Schedule at which Snapshot copies are captured on the volume. Some common schedules already defined in the system are hourly, daily, weekly, at 15 minute intervals, and at 5 minute intervals. Snapshot copy policies with custom schedules can be referenced.
copies
count
integer
The number of Snapshot copies to maintain for this schedule.
prefix
string
The prefix to use while creating Snapshot copies at regular intervals.
schedule
schedule
snapmirror_label
string
Label for SnapMirror operations
svm
_links
_links
name
string
The name of the SVM.
uuid
string
snapshot_policy
The Snapshot copy policy object is associated with a read-write volume used to create and delete Snapshot copies at regular intervals.
_links
_links
comment
string
A comment associated with the Snapshot copy policy.
copies
array[copies]
enabled
boolean
Is the Snapshot copy policy enabled?
name
string
Name of the Snapshot copy policy.
scope
string
Set to "svm" when the request is on a data SVM, otherwise set to "cluster".
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
