Retrieves a collection of event filters
learn more
doc /support/ems/filters](#docs-support-support_ems_filters)
GET /support/ems/filters
Retrieves a collection of event filters.
Related ONTAP commands
event filter show
Learn more
name |
string |
query |
False |
Filter by name |
rules.type |
string |
query |
False |
Filter by rules.type |
rules.index |
integer |
query |
False |
Filter by rules.index |
rules.message_criteria.severities |
string |
query |
False |
Filter by rules.message_criteria.severities |
rules.message_criteria.snmp_trap_types |
string |
query |
False |
Filter by rules.message_criteria.snmp_trap_types |
rules.message_criteria.name_pattern |
string |
query |
False |
Filter by rules.message_criteria.name_pattern |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
The default is true for GET calls. When set to false, only the number of records is returned. |
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When iterating over a collection, the default is 15 seconds. ONTAP returns earlier if either max records or the end of the collection is reached. |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 3,
"records": [
"name": "snmp-traphost",
"rules": [
"index": 1,
"message_criteria": {
"related": {
"name_pattern": "callhome.*",
"severities": "error,informational",
"snmp_trap_types": "standard|built_in"
"type": "include"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
_links
related |
message_criteria
Matching message definitions for the filter. A property must be specified.
_links |
name_pattern |
string |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified. |
severities |
string |
A comma-separated list of severities or a wildcard. |
snmp_trap_types |
string |
A comma separated list of snmp_trap_types or a wildcard. |
rules
Rule for an event filter
_links |
index |
integer |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list. |
message_criteria |
Matching message definitions for the filter. A property must be specified. |
type |
string |
Rule type |
records
_links |
name |
string |
Filter name |
rules |
array[rules] |
Array of event filter rules on which to match. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
