Manage AutoSupport configuration
Overview
AutoSupport is NetApp's call home mechanism. AutoSupport sends configuration details, status details, and error reporting details to NetApp.
This endpoint supports both GET and PATCH calls. GET is used to retrieve AutoSupport configuration details for the cluster and PATCH is used to modify the AutoSupport configuration of the cluster. GET calls can also be used to check AutoSupport connectivity.
Configuring 'to' addresses
The following example configures AutoSupport to send emails to 'to' addresses.
# The API:
PATCH /support/autosupport
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/autosupport" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"to\": [ \"abc@netapp.com\", \"xyz@netapp.com\" ]}"
# The response:
200 OK
Configuring 'SMTP' transport
The following example configures AutoSupport to use 'SMTP' transport. The default transport is 'HTTPS'.
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/autosupport" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "{ \"transport\": \"smtp\"}"
# The response:
200 OK
Retrieving the AutoSupport configuration
The following example retrieves AutoSupport configuration for the cluster.
# The API:
GET /support/autosupport
# The call:
curl -X GET "https://<mgmt-ip>/api/support/autosupport" -H "accept: application/hal+json" OR
curl -X GET "https://<mgmt-ip>/api/support/autosupport?fields=*" -H "accept: application/hal+json"
# The response:
200 OK
"enabled": true,
"mail_hosts": [
"mailhost"
"from": "Postmaster",
"to": [
"abc@netapp.com",
"xyz@netapp.com"
"contact_support": true,
"transport": "smtp",
"proxy_url": "",
"is_minimal": false,
"href": "/api/support/autosupport"
Retrieving AutoSupport connectivity issues
The following example retrieves AutoSupport connectivity issues for the cluster. The fields=issues parameter must be specified, for the response to return any connectivity issues. The corrective_action section might contain commands which needs to be executed on the ONTAP CLI.
Note that the connectivity check can take up to 10 seconds to complete.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/support/autosupport?fields=issues" -H "accept: application/hal+json"
# The response:
200 OK
"issues": [
"node": {
"name": "node3",
"uuid": "0ecfd0a6-f1b3-11e8-9d9f-005056bbaadc",
"href": "/api/cluster/nodes/0ecfd0a6-f1b3-11e8-9d9f-005056bbaadc"
"issue": {
"message": "SMTP connectivity check failed for destination: mailhost. Error: Could not resolve host - 'mailhost'",
"code": "53149746"
"corrective_action": {
"message": "Check the hostname of the SMTP server",
"code": "53149746"
"node": {
"name": "node3",
"issue": {
"message": "AutoSupport OnDemand is disabled when \"-transport\" is not set to \"https\".",
"code": "53149740"
"message": "Run \"system node autosupport modify -transport https -node <node name>\" to set \"-transport\" to \"https\".",
"code": "53149740"
Retrieving AutoSupport configuration and connectivity issues
The following example retrieves AutoSupport configuration and connectivity issues on the cluster. Use fields=*,issues parameter to return both configuration and connectivity issues.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/support/autosupport?fields=*%2Cissues" -H "accept: application/hal+json"
# The response:
200 OK
"enabled": true,
"mail_hosts": [
"mailhost"
"to": [
"abc@netapp.com",
"xyz@netapp.com"
"proxy_url": "",
"issues": [
"node": {
"name": "node3",
"issue": {
"code": "53149746"
"code": "53149746"
"node": {
"name": "node3",
"issue": {
"code": "53149740"
"code": "53149740"
