Manage role privilege details
Overview
This API is used to configure the role privileges (tuples of REST URI path and its access levels). It also retrieves all of the privilege tuples for a role and can add a tuple to an existing role.
The role can be SVM-scoped or cluster-scoped.
Specify the owner UUID and the role name in the URI path. The owner UUID corresponds to the UUID of the SVM for which the role has been created and can be obtained from the response body of a GET call performed on one of the following APIs:
/api/security/roles for all the roles
/api/security/roles/?scope=svm for SVM-scoped roles
/api/security/roles/?owner.name=
The pre-defined roles can be retrieved but cannot be updated. |
Adding a privilege tuple for an existing custom role
# The API:
POST "/security/roles/{owner.uuid}/{name}/privileges"
# The call:
curl -k -u <cluster_admin>:<password> -X POST "https://<mgmt-ip>/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges" -d '{"access":"readonly","path":"/api/protocols"}'
Retrieving all the privilege tuples for a role
# The API:
GET "/api/security/roles/{owner.uuid}/{name}/privileges"
# The call:
curl -k -u <cluster_admin>:<password> -X GET "https://<mgmt-ip>/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges"
# The response:
"records": [
"path": "/api/application",
"access": "all",
"href": "/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/%2Fapi%2Fapplication"
"path": "/api/protocols",
"access": "readonly",
"href": "/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges/%2Fapi%2Fprotocols"
"num_records": 2,
"href": "/api/security/roles/aaef7c38-4bd3-11e9-b238-0050568e2e25/svm_role1/privileges"
