Update a cloud target
PATCH /cloud/targets/{uuid}
Updates the cloud target specified by the UUID with the fields in the body. This request starts a job and returns a link to that job.
Related ONTAP commands
storage aggregate object-store config modify
Learn more
uuid |
string |
path |
True |
Cloud target UUID |
ignore_warnings |
boolean |
query |
False |
Specifies whether or not warnings should be ignored. |
check_only |
boolean |
query |
False |
Do not modify the configuration, only check that the PATCH request succeeds. |
Request Body
| Name | Type | Description |
_links |
access_key |
string |
Access key ID for AWS_S3 and other S3 compatible provider types. |
authentication_type |
string |
Authentication used to access the target. Snapmirror does not yet support CAP. Required in POST. |
azure_account |
string |
Azure account |
azure_private_key |
string |
Azure access key |
cap_url |
string |
This parameter is available only when auth-type is CAP. It specifies a full URL of the request to a CAP server for retrieving temporary credentials (access-key, secret-pasword, and session token) for accessing the object store. |
certificate_validation_enabled |
boolean |
Is SSL/TLS certificate validation enabled? The default value is true. This can only be modified for SGWS and IBM_COS provider types. |
name |
string |
Cloud target name |
port |
integer |
Port number of the object store that ONTAP uses when establishing a connection. Required in POST. |
secret_password |
string |
Secret access key for AWS_S3 and other S3 compatible provider types. |
server |
string |
Fully qualified domain name of the object store server. Required on POST. For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3- |
snapmirror_use |
string |
Use of the cloud target by SnapMirror. |
ssl_enabled |
boolean |
SSL/HTTPS enabled or not |
svm |
This field is only applicable when used for SnapMirror. For POST and PATCH, SVM information is required for SnapMirror targets and not allowed for FabricPool targets. |
used |
integer |
The amount of cloud space used by all the aggregates attached to the target, in bytes. This field is only populated for FabricPool targets. The value is recalculated once every 5 minutes. |
uuid |
string |
Cloud target UUID |
Example request
"href": "/api/resourcelink"
"access_key": "string",
"authentication_type": "string",
"azure_account": "string",
"azure_private_key": "string",
"cap_url": "https://123.45.67.89:1234/CAP/api/v1/credentials?agency=myagency&mission=mymission&role=myrole",
"name": "string",
"secret_password": "string",
"server": "string",
"snapmirror_use": "string",
"svm": {
"name": "svm1",
"used": 0,
"uuid": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ipspace
IPspace to use in order to reach the cloud target.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
cloud_target
_links |
access_key |
string |
string |
azure_account |
string |
Azure account |
azure_private_key |
string |
Azure access key |
cap_url |
string |
boolean |
name |
string |
Cloud target name |
port |
integer |
secret_password |
string |
server |
string |
snapmirror_use |
string |
ssl_enabled |
boolean |
svm |
used |
integer |
uuid |
string |
Cloud target UUID |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
