Update the cluster software version
PATCH /cluster/software
Upgrades the cluster software version. Setting version  triggers the installation of the package to start. To validate the package for installation but not perform the installation, use the validate_only field on request.
Important note:
Setting 'version' triggers the package installation.
To validate the package for installation but not perform the installation, use the validate_only field on the request.
Required properties
version- Software version to be installed on the cluster
Recommended optional parameters
validate_only- Required to validate a software package before an upgrade -
skip_warnings- Used to skip validation warnings when starting a software upgrade -
action- Used to pause, resume, or cancel an ongoing software upgrade
Related ONTAP commands
cluster image validate -
cluster image update -
cluster image pause-update -
cluster image resume-update -
cluster image cancel-update
Learn more
validate_only  |
boolean  |
query  |
False  |
Validate the operation and its parameters, without actually performing the operation.  |
skip_warnings  |
boolean  |
query  |
False  |
Ignore warnings and proceed with the install.  |
action  |
string  |
query  |
False  |
Requests an upgrade to pause, resume, or cancel. Note that not all upgrades support these actions. An upgrade can only be resumed if it is in the paused state. When a request to cancel an upgrade is successful, the upgrade state changes to either success or failure.
Request Body
| Name | Type | Description |
_links  |
action  |
string  |
User triggered action to apply to the install operation  |
elapsed_duration  |
integer  |
Elapsed time during the upgrade or validation operation  |
estimated_duration  |
integer  |
Estimated time remaining until completion of the upgrade or validation operation.  |
metrocluster  |
nodes  |
array[software_node_reference]  |
List of nodes and active versions.  |
pending_version  |
string  |
Version being installed on the system.
state  |
string  |
Operational state of the upgrade  |
status_details  |
Display status details.  |
update_details  |
Display update procress details.  |
validation_results  |
List of validation warnings, errors, and advice.  |
version  |
string  |
Version of ONTAP installed and currently active on the system. During PATCH, using the 'validate_only' parameter on the request executes pre-checks, but does not perform the full installation.
Example request
      "href": "/api/resourcelink"
  "action": "pause",
  "elapsed_duration": 2140,
  "estimated_duration": 5220,
  "metrocluster": {
    "clusters": [
        "estimated_duration": 3480,
        "name": "cluster_A",
        "state": "in_progress"
    "progress_details": "Switchover in progress.",
    "progress_summary": "MetroCluster updated successfully."
  "nodes": [
      "name": "node1",
      "version": "ONTAP_X"
  "pending_version": "ONTAP_X_1",
  "state": "completed",
  "status_details": [
      "action": "string",
      "end_time": "2019-02-02 19:00:00 UTC",
      "message": "Post-update checks successful",
      "name": "initialize",
      "node": {
        "name": "node1"
      "start_time": "2019-02-02 19:00:00 UTC",
      "state": "failed"
  "update_details": [
      "elapsed_duration": 2100,
      "estimated_duration": 4620,
      "node": {
        "name": "node1"
      "phase": "Pre-update checks",
      "state": "failed"
  "validation_results": [
      "action": "string",
      "message": "string",
      "status": "warning",
      "update_check": "nfs_mounts"
Status: 202, Accepted
job  |
  "job": {
    "uuid": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
software_mcc_reference
elapsed_duration  |
integer  |
Elapsed duration of update time (in seconds) in MetroCluster.  |
integer  |
Estimated duration of update time (in seconds) in MetroCluster.  |
name  |
string  |
Name of the site in MetroCluster.  |
state  |
Upgrade state of MetroCluster.  |
metrocluster
clusters  |
array[software_mcc_reference]  |
List of MetroCluster sites, statuses, and active versions.  |
progress_details  |
string  |
MetroCluster update progress details.  |
progress_summary  |
string  |
MetroCluster update progress summary.  |
name  |
string  |
Name of the node.  |
version  |
string  |
ONTAP version of the node.
node
name  |
string  |
Name of the node to be retrieved for status details.  |
software_status_details_reference
action  |
string  |
Corrective action to be taken to resolve the status error.  |
end_time  |
string  |
End time for each status phase.  |
message  |
string  |
Detailed message of the phase details.  |
name  |
string  |
Name of the phase to be retrieved for status details.  |
node  |
start_time  |
string  |
Start time for each status phase.  |
state  |
string  |
Status of the phase  |
node
name  |
string  |
Name of the node to be retrieved for update details.  |
software_update_details_reference
elapsed_duration  |
integer  |
Elapsed duration for each update phase  |
integer  |
Estimated duration for each update phase  |
node  |
phase  |
string  |
Phase details  |
state  |
string  |
State of the update phase  |
software_validation_reference
action  |
string  |
Corrective action to resolve errors or warnings for update checks.  |
message  |
string  |
Details of the error or warning encountered by the update check.  |
status  |
string  |
Status of this update check.  |
update_check  |
string  |
Name of the update check to be validated.  |
software_reference
_links  |
action  |
string  |
elapsed_duration  |
integer  |
integer  |
metrocluster  |
nodes  |
pending_version  |
string  |
state  |
string  |
status_details  |
update_details  |
version  |
string  |
job_link
_links  |
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
