Updates an fc port
learn more
doc /network/fc/ports](#docs-networking-network_fc_ports)
PATCH /network/fc/ports/{uuid}
Updates an FC port.
Related ONTAP commands
network fcp adapter modify
Learn more
uuid |
string |
path |
True |
The unique identifier for the FC port. |
Request Body
| Name | Type | Description |
_links |
description |
string |
A description of the FC port. |
enabled |
boolean |
The administrative state of the FC port. If this property is set to false, all FC connectivity to FC interfaces are blocked. Optional in PATCH. |
fabric |
Properties of the fabric to which the FC port is attached. |
name |
string |
The FC port name. |
node |
physical_protocol |
string |
The physical network protocol of the FC port. |
speed |
The physical device speed related properties of the FC port. |
state |
string |
The operational state of the FC port.
supported_protocols |
array[string] |
The network protocols supported by the FC port. |
transceiver |
Properties of the transceiver connected to the FC port. |
uuid |
string |
The unique identifier of the FC port. |
wwnn |
string |
The base world wide node name (WWNN) for the FC port. |
wwpn |
string |
The base world wide port name (WWPN) for the FC port. |
Example request
"href": "/api/resourcelink"
"description": "Fibre Channel Target Adapter 0a (ACME Fibre Channel Adapter, rev. 1.0.0, 8G)",
"fabric": {
"connected_speed": 16,
"name": "string",
"port_address": "52100A",
"switch_port": "ssan-g620-03:33"
"name": "0a",
"node": {
"name": "node1",
"physical_protocol": "string",
"speed": {
"configured": "auto",
"maximum": 32
"state": "online",
"supported_protocols": [
"string"
"transceiver": {
"capabilities": [
16
"form-factor": "string",
"manufacturer": "Acme, Inc.",
"part_number": "string"
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"wwnn": "20:00:00:50:56:b4:13:a8",
"wwpn": "20:00:00:50:56:b4:13:a8"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374085 |
The node where the Fibre Channel port is located is offline. |
5374087 |
The Fibre Channel port has active Fibre Channel interfaces and cannot be disabled. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
fabric
connected |
boolean |
Reports if the physical port has established a connection with the FC fabric. |
connected_speed |
integer |
The negotiated data rate between the target FC port and the fabric in gigabits per second. |
name |
string |
The name of the fabric to which the port is connected. This is only available when the FC port is connected to a fabric. There is an added cost to retrieving this property's value. It is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
port_address |
string |
The FC port address of the host bus adapter (HBA) physical port. Each FC port in an FC switched fabric has its own unique FC port address for routing purposes. The FC port address is assigned by a switch in the fabric when that port logs in to the fabric. This property refers to the FC port address given to the physical host bus adapter (HBA) port when the port performs a fabric login (FLOGI). This is useful for obtaining statistics and diagnostic information from FC switches. This is a six-digit hexadecimal encoded numeric value. |
switch_port |
string |
The switch port to which the FC port is connected. |
node
_links |
name |
string |
uuid |
string |
speed
configured |
string |
The configured speed of the FC port in gigabits per second. |
maximum |
string |
The maximum speed supported by the FC port in gigabits per second. |
transceiver
capabilities |
array[integer] |
The speeds of which the transceiver is capable in gigabits per second. |
form-factor |
string |
The form factor of the transceiver. Possible values are:
manufacturer |
string |
The manufacturer of the transceiver. |
part_number |
string |
The part number of the transceiver. |
fc_port
A Fibre Channel (FC) port is the physical port of an FC adapter on an ONTAP cluster node that can be connected to an FC network to provide FC network connectivity. An FC port defines the location of an FC interface within the ONTAP cluster.
_links |
description |
string |
enabled |
boolean |
fabric |
name |
string |
The FC port name. |
node |
physical_protocol |
string |
speed |
state |
string |
array[string] |
transceiver |
uuid |
string |
wwnn |
string |
wwpn |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
