Update an IP interface
PATCH /network/ip/interfaces/{uuid}
Updates an IP interface.
Related ONTAP commands
network interface migrate -
network interface modify -
network interface rename -
network interface revert
Learn more
uuid |
string |
path |
True |
IP interface UUID |
Request Body
| Name | Type | Description |
_links |
enabled |
boolean |
The administrative state of the interface. |
ip |
IP information |
location |
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node. |
name |
string |
Interface name |
service_policy |
services |
array[string] |
The services associated with the interface. |
state |
string |
The operational state of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
Example request
"href": "/api/resourcelink"
"ip": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"location": {
"failover": "string",
"home_port": {
"name": "e1b",
"node": {
"name": "node1"
"node": {
"name": "node1",
"port": {
"name": "e1b",
"node": {
"name": "node1"
"name": "dataLif1",
"service_policy": {
"name": "default-intercluster",
"services": [
"data_nfs"
"state": "string",
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"vip": null
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1967143 |
Cannot patch home_port for a VIP interface. Invalid parameters location.home_port.uuid and location.home_port.name specified. |
1967141 |
Cannot patch home_port for a VIP interface. Invalid parameter location.home_port.uuid specified. |
1967142 |
Cannot patch home_port for a VIP interface. Invalid parameter location.home_port.name specified. |
1967140 |
Cannot patch port for a VIP interface. Invalid parameters location.port.uuid and location.port.name specified. |
1967138 |
Cannot patch port for a VIP interface. Invalid parameter location.port.uuid specified. |
1967139 |
Cannot patch port for a VIP interface. Invalid parameter location.port.name specified. |
1967120 |
The specified service_policy.name does not match the specified service policy name of service_policy.uuid. |
1967121 |
Invalid service_policy.uuid specified. |
1967113 |
The specified location.port.name does not match the port name of location.port.uuid. |
1967114 |
Invalid location.port.uuid specified. |
1967134 |
The specified location.port.uuid and location.port.name are invalid. |
1967132 |
The specified location.port.uuid is invalid. |
1967133 |
The specified location.port.name is invalid. |
1967115 |
The specified location.node.name does not match the node name of location.node.uuid. |
1967116 |
The specified location.port.node.name does not match the node name of location.node.uuid. |
1967117 |
The specified location.port.node.name does not match location.node.name. |
1967118 |
Node must be specified by at least one location.node or location.port field. |
1967119 |
The specified location.node.name does not match the node name of location.port.uuid. |
1967106 |
The specified location.home_port.name does not match the specified port name of location.home_port.uuid. |
1967107 |
Invalid location.home_port.uuid specified. |
1967111 |
Home node must be specified by at least one location.home_node, location.home_port, or location.broadcast_domain field. |
1967129 |
The specified location.home_port.uuid is invalid. |
1967130 |
The specified location.home_port.name is invalid. |
1967131 |
The specified location.home_port.uuid and location.home_port.name are invalid. |
1967145 |
The specified location.failover is invalid. |
1966138 |
The same IP address may not be used for both a mgmt interface and a gateway address. |
1376963 |
Duplicate IP address |
1966229 |
You cannot patch the "location.node" or "location.port" fields to migrate interfaces using FCP and iSCSI data protocols. Instead perform the following PATCH operations on the interface: set the "enabled" field to "false"; change one or more "location.home_port" fields to migrate the interface; and then set the "enabled" field to "true". |
href |
string |
_links
self |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
ipspace
Either the UUID or name must be supplied on POST for cluster-scoped objects.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
broadcast_domain
Broadcast domain UUID along with a readable name.
_links |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
home_node
_links |
name |
string |
uuid |
string |
node
name |
string |
Name of node on which the port is located. |
home_port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links |
name |
string |
node |
uuid |
string |
node
_links |
name |
string |
uuid |
string |
port
_links |
name |
string |
node |
uuid |
string |
location
auto_revert |
boolean |
failover |
string |
Defines where an interface may failover. |
home_port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
is_home |
boolean |
node |
port |
service_policy
_links |
name |
string |
uuid |
string |
svm
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST.
_links |
name |
string |
The name of the SVM. |
uuid |
string |
ip_interface
_links |
enabled |
boolean |
ip |
IP information |
location |
name |
string |
Interface name |
service_policy |
services |
array[string] |
state |
string |
uuid |
string |
