REST API reference
Reorders a cifs home directory search path
learn more
  • [doc /protocols/cifs/home-directory/search-paths](#docs-nas-protocols_cifs_home-directory_search-paths)
PATCH /protocols/cifs/home-directory/search-paths/{svm.uuid}/{index}
Reorders a CIFS home directory search path.
  • cifs server home-directory search-path reorder
svm.uuid
string
path
True
index
integer
path
True
Home directory search path index
new_index
integer
query
False
New position for the home directory search path
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655463
Failed to reorder the search-path because the new-index is invalid. It cannot be '0' and it cannot go beyond the current entries
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
