Update CIFS mandatory and optional parameters
PATCH /protocols/cifs/services/{svm.uuid}
Updates both the mandatory and optional parameters of the CIFS configuration. Ensure the CIFS server is administratively disabled when renaming the CIFS server or modifying the ad_domain properties.
Related ONTAP commands
vserver cifs server modify -
vserver cifs server options modify -
vserver cifs security modify -
vserver cifs server add-netbios-aliases -
vserver cifs server remove-netbios-aliases
Learn more
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
Request Body
| Name | Type | Description |
_links  |
ad_domain  |
comment  |
string  |
A descriptive text comment for the CIFS server. SMB clients can see the CIFS server comment when browsing servers on the network. If there is a space in the comment, you must enclose the entire string in quotation marks.  |
default_unix_user  |
string  |
Specifies the UNIX user to which any authenticated CIFS user is mapped to, if the normal user mapping rules fails.  |
enabled  |
boolean  |
Specifies if the CIFS service is administratively enabled.  |
name  |
string  |
The name of the CIFS server.  |
netbios  |
security  |
svm  |
SVM, applies only to SVM-scoped objects.  |
Example request
      "href": "/api/resourcelink"
  "ad_domain": {
    "fqdn": "example.com",
    "organizational_unit": "string",
    "password": "string"
  "comment": "This CIFS Server Belongs to CS Department",
  "default_unix_user": "string",
  "name": "CIFS1",
  "netbios": {
    "aliases": [
      "ALIAS_1",
      "ALIAS_2",
      "ALIAS_3"
    "wins_servers": [
      "10.224.65.20",
      "10.224.65.21"
  "security": {
    "restrict_anonymous": "string"
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job  |
  "job": {
    "uuid": "string"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
ad_domain
fqdn  |
string  |
The fully qualified domain name of the Windows Active Directory to which this CIFS server belongs. A CIFS server appears as a member of Windows server object in the Active Directory store. POST and PATCH only.  |
organizational_unit  |
string  |
Specifies the organizational unit within the Active Directory domain to associate with the CIFS server. POST and PATCH only.  |
password  |
string  |
The account password used to add this CIFS server to the Active Directory. This is not audited.  |
cifs_netbios
aliases  |
array[string]  |
enabled  |
boolean  |
Specifies whether NetBios name service (NBNS) is enabled for the CIFS. If this service is enabled, the CIFS server will start sending the broadcast for name registration.  |
wins_servers  |
array[string]  |
cifs_service_security
kdc_encryption  |
boolean  |
Specifies whether AES-128 and AES-256 encryption is enabled for all Kerberos-based communication with the Active Directory KDC. To take advantage of the strongest security with Kerberos-based communication, AES-256 and AES-128 encryption can be enabled on the CIFS server. Kerberos-related communication for CIFS is used during CIFS server creation on the SVM, as well as during the SMB session setup phase. The CIFS server supports the following encryption types for Kerberos communication:
restrict_anonymous  |
string  |
Specifies what level of access an anonymous user is granted. An anonymous user (also known as a "null user") can list or enumerate certain types of system information from Windows hosts on the network, including user names and details, account policies, and share names. Access for the anonymous user can be controlled by specifying one of three access restriction settings. The available values are:
smb_encryption  |
boolean  |
Specifies whether encryption is required for incoming CIFS traffic.  |
smb_signing  |
boolean  |
Specifies whether signing is required for incoming CIFS traffic. SMB signing helps to ensure that network traffic between the CIFS server and the client is not compromised.  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
cifs_service
_links  |
ad_domain  |
comment  |
string  |
default_unix_user  |
string  |
enabled  |
boolean  |
name  |
string  |
netbios  |
security  |
svm  |
job_link
_links  |
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
