REST API reference
Updates a share-level acl on a cifs share
learn more
  • [doc /protocols/cifs/shares/{svmuuid}/{share}/acls](#docs-nas-protocols_cifs_shares_{svmuuid}_{share}_acls)
PATCH /protocols/cifs/shares/{svm.uuid}/{share}/acls/{user_or_group}/{type}
Updates a share-level ACL on a CIFS share.
  • vserver cifs share access-control modify
svm.uuid
string
path
True
share
string
path
True
Share name
user_or_group
string
path
True
User or group name
type
string
path
True
User or group type
Request Body
Name Type Description
_links
_links
permission
string
Specifies the access rights that a user or group has on the defined CIFS Share. The following values are allowed:
  • no_access - User does not have CIFS share access
  • read - User has only read access
  • change - User has change access
  • full_control - User has full_control access
Example request
      "href": "/api/resourcelink"
  "permission": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655516
The share ACL does not exist for given user and share
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
cifs_share_acl
The permissions that users and groups have on a CIFS share.
_links
_links
permission
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
