REST API reference
Updates the unix symbolic link mapping for cifs clients
learn more
  • [doc /protocols/cifs/unix-symlink-mapping](#docs-nas-protocols_cifs_unix-symlink-mapping)
PATCH /protocols/cifs/unix-symlink-mapping/{svm.uuid}/{unix_path}
Updates the UNIX symbolic link mapping for CIFS clients.
  • vserver cifs symlink modify
svm.uuid
string
path
True
unix_path
string
path
True
UNIX symbolic link path
Request Body
Name Type Description
_links
_links
svm
svm
target
cifs_target
Example request
      "href": "/api/resourcelink"
  "svm": {
    "name": "svm1",
  "target": {
    "locality": "string",
    "path": "/dir1/dir2/",
    "server": "ENGCIFS",
    "share": "ENG_SHARE"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
655573
Failed to modify the symlink mapping to target path because it contains illegal characters or is too long
655575
Failed to modify the symlink mapping to target server because it contains illegal characters or is too long
655547
Failed to modify symlink mapping becasue administrative share cannot be used as target share
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
cifs_target
home_directory
boolean
Specify if the destination share is a home directory.
locality
string
Specifies whether the CIFS symbolic link is a local link or wide link. The following values are supported:
  • local - Local symbolic link maps only to the same CIFS share.
  • widelink - Wide symbolic link maps to any CIFS share on the network.
path
string
Specifies the CIFS path on the destination to which the symbolic link maps. The final path is generated by concatenating the CIFS server name, the share name, the cifs-path and the remaining path in the symbolic link left after the prefix match. This value is specified by using a UNIX-style path name. The trailing forward slash is required for the full path name to be properly interpreted.
server
string
Specifies the destination CIFS server where the UNIX symbolic link is pointing. This field is mandatory if the locality of the symbolic link is 'widelink'. You can specify the value in any of the following formats:
  • DNS name of the CIFS server.
  • IP address of the CIFS server.
  • NetBIOS name of the CIFS server.
share
string
Specifies the CIFS share name on the destination CIFS server to which the UNIX symbolic link is pointing.
ONTAP allows for both CIFS and NFS access to the same datastore. This datastore can contain symbolic links created by UNIX clients which can point anywhere from the perspective of the UNIX client. To Access such UNIX symlink from CIFS share, we need to create a CIFS symbolic link path mapping from a UNIX symlink and target it as a CIFS path.
_links
_links
svm
svm
target
cifs_target
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
