REST API reference
Updates a particular fpolicy policy configuration for a specified svm patch can be used to enable or disable the policy when enabling a policy, you must specify the policy priority the policy priority of the policy is not required when disabling the policy if the policy is enabled, the fpolicy policy engine cannot be modified
  • fpolicy policy scope modify
  • fpolicy enable
  • fpolicy disable # learn more
  • [doc /protocols/fpolicy/{svmuuid}/policies](#docs-nas-protocols_fpolicy_{svmuuid}_policies)
PATCH /protocols/fpolicy/{svm.uuid}/policies/{name}
Updates a particular FPolicy policy configuration for a specified SVM. PATCH can be used to enable or disable the policy. When enabling a policy, you must specify the policy priority. The policy priority of the policy is not required when disabling the policy. If the policy is enabled, the FPolicy policy engine cannot be modified.
  • fpolicy policy modify
  • fpolicy enable
  • fpolicy disable
svm.uuid
string
path
True
name
string
path
True
Request Body
Name Type Description
enabled
boolean
Specifies if the policy is enabled on the SVM or not. If no value is mentioned for this field but priority is set, then this policy will be enabled.
engine
fpolicy_engine_reference
FPolicy external engine
events
array[fpolicy_event_reference]
mandatory
boolean
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances.
priority
integer
Specifies the priority that is assigned to this policy.
scope
scope
Example request
  "engine": {
        "href": "/api/resourcelink"
    "name": "string"
  "events": [
    "event_nfs_close",
    "event_open"
  "scope": {
    "exclude_export_policies": [
      "string"
    "exclude_extension": [
      "string"
    "exclude_shares": [
      "string"
    "exclude_volumes": [
      "vol1",
      "vol_svm1",
    "include_export_policies": [
      "string"
    "include_extension": [
      "string"
    "include_shares": [
      "sh1",
      "share_cifs"
    "include_volumes": [
      "vol1",
      "vol_svm1"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
9765026
The priority must be specified when enabling the FPolicy policy
9765025
Cannot disable an FPolicy policy when the priority is specified
9764899
Cannot modify an FPolicy engine when the policy is enabled
9764899
Deletion of a cluster policy is not supported
9764908
An FPolicy policy is already enabled
9764907
An FPolicy policy is already disabled
9765029
An FPolicy was modified but disable/enable failed as the policy is already disabled/enabled
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
name
string
The name of the FPolicy external engine.
FPolicy events
_links
_links
name
string
scope
array[string]
exclude_extension
array[string]
exclude_shares
array[string]
exclude_volumes
array[string]
array[string]
include_extension
array[string]
include_shares
array[string]
include_volumes
array[string]
fpolicy_policy
enabled
boolean
engine
events
mandatory
boolean
priority
integer
scope
scope
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
