Update an NVMe subsystem
PATCH /protocols/nvme/subsystems/{uuid}
Updates an NVMe subsystem.
Related ONTAP commands
vserver nvme subsystem modify
Learn more
uuid  |
string  |
path  |
True  |
The unique identifier of the NVMe subsystem.  |
Request Body
| Name | Type | Description |
_links  |
comment  |
string  |
A configurable comment for the NVMe subsystem. Optional in POST and PATCH.  |
hosts  |
array[hosts]  |
io_queue  |
The properties of the submission queue used to submit I/O commands for execution by the NVMe controller.  |
serial_number  |
string  |
The serial number of the NVMe subsystem.  |
subsystem_maps  |
array[subsystem_maps]  |
The NVMe namespaces mapped to the NVMe subsystem. There is an added cost to retrieving property values for   |
svm  |
SVM, applies only to SVM-scoped objects.  |
target_nqn  |
string  |
The NVMe qualified name (NQN) used to identify the NVMe storage target.  |
uuid  |
string  |
Example request
      "href": "/api/resourcelink"
  "comment": "string",
  "hosts": [
      "nqn": "nqn.1992-01.example.com:string"
  "io_queue": {
    "default": {
      "count": 4,
      "depth": 16
  "serial_number": "wCVsgFMiuMhVAAAAAAAB",
  "subsystem_maps": [
      "anagrpid": "00103050h",
      "namespace": {
        "name": "/vol/vol1/namespace1",
      "nsid": "00000001h"
  "svm": {
    "name": "svm1",
  "target_nqn": "nqn.1992-01.example.com:string",
Status: 200, Ok
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
hosts
An NVMe host of an NVMe subsystem.
_links  |
nqn  |
string  |
default
The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem.
count  |
integer  |
The number of host I/O queue pairs.  |
depth  |
integer  |
The host I/O queue depth.  |
io_queue
default  |
The default I/O queue parameters inherited by NVMe hosts in the NVMe subsystem.  |
namespace
An NVMe namespace mapped to the NVMe subsystem.
_links  |
name  |
string  |
The name of the NVMe namespace.  |
uuid  |
string  |
The unique identifier of the NVMe namespace.  |
subsystem_maps
_links  |
anagrpid  |
string  |
The Asymmetric Namespace Access Group ID (ANAGRPID) of the NVMe namespace. The format for an ANAGRPIP is 8 hexadecimal digits (zero-filled) followed by a lower case "h".  |
namespace  |
An NVMe namespace mapped to the NVMe subsystem.  |
nsid  |
string  |
The NVMe namespace identifier. This is an identifier used by an NVMe controller to provide access to the NVMe namespace. The format for an NVMe namespace identifier is 8 hexadecimal digits (zero-filled) followed by a lower case "h".  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
nvme_subsystem
An NVMe subsystem maintains configuration state and namespace access control for a set of NVMe-connected hosts.
_links  |
comment  |
string  |
hosts  |
array[hosts]  |
io_queue  |
serial_number  |
string  |
subsystem_maps  |
svm  |
target_nqn  |
string  |
uuid  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
