Update iSCSI credentials
PATCH /protocols/san/iscsi/credentials/{svm.uuid}/{initiator}
Updates specified iSCSI credentials.
Related ONTAP commands
vserver iscsi security add-initiator-address-ranges -
vserver iscsi security default -
vserver iscsi security modify -
vserver iscsi security remove-initiator-address-ranges
Learn more
svm.uuid  |
string  |
path  |
True  |
The unique identifier of an SVM.  |
initiator  |
string  |
path  |
True  |
The iSCSI initiator of the credentials object.  |
add_initiator_addresses  |
boolean  |
query  |
False  |
If true, the initiator addresses in the body merge into the existing addresses in the iSCSI security object rather than replace the existing addresses.
remove_initiator_addresses  |
boolean  |
query  |
False  |
If true, the initiator addresses in the body are removed from the existing addresses in the iSCSI security object rather than replace the existing addresses.
Request Body
| Name | Type | Description |
_links  |
authentication_type  |
string  |
The iSCSI authentication type. Required in POST and optional in PATCH.  |
chap  |
Challenge-Handshake Authentication Protocol (CHAP) credentials.  |
initiator_address  |
Initiator address ranges.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
Example request
      "href": "/api/resourcelink"
  "authentication_type": "string",
  "chap": {
    "inbound": {
      "password": "string",
      "user": "string"
    "outbound": {
      "user": "string"
  "initiator_address": {
    "masks": [
        "address": "10.10.10.7",
        "family": "string",
        "netmask": "24"
    "ranges": [
        "end": "10.10.10.7",
        "family": "string",
        "start": "10.10.10.7"
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462  |
An SVM with the specified UUID does not exist.  |
2621706  |
Both the SVM UUID and SVM name were supplied, but they do not refer to the same SVM.  |
2621707  |
No SVM was specified. Either   |
5374145  |
The iSCSI security password must contain an even number of valid hex digits.  |
5374900  |
Setting the CHAP authentication properties are not supported with authentication types none or deny.  |
5374147  |
The CHAP inbound and outbound passwords must be different.  |
5374149  |
The inbound user and password properties are required for CHAP authentication.  |
5374150  |
Outbound CHAP authentication requires an outbound password.  |
5374155  |
The functionality is not supported for the default security credential.  |
5374855  |
The value for property   |
5374856  |
5374895  |
The iSCSI security credential does not exist on the specified SVM.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
inbound
Inbound CHAP credentials.
password  |
string  |
The inbound CHAP password. Write-only; optional in POST and PATCH.  |
user  |
string  |
The inbound CHAP user name. Optional in POST and PATCH.  |
outbound
Output CHAP credentials.
password  |
string  |
The outbound CHAP password. Write-only; optional in POST and PATCH.  |
user  |
string  |
The outbound CHAP user name. Optional in POST and PATCH.  |
chap
inbound  |
Inbound CHAP credentials.  |
outbound  |
Output CHAP credentials.  |
ip_info
IP information
address  |
string  |
IPv4 or IPv6 address  |
family  |
string  |
IPv4 or IPv6  |
netmask  |
string  |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length.  |
ip_address_range
IP address range
end  |
string  |
family  |
string  |
IPv4 or IPv6  |
start  |
string  |
initiator_address
masks  |
array[ip_info]  |
ranges  |
array[ip_address_range]  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
iscsi_credentials
_links  |
string  |
chap  |
initiator_address  |
svm  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
