      Update a SAML service provider configuration
PATCH /security/authentication/cluster/saml-sp
Updates a SAML service provider configuration.
Learn more
Request Body
| Name | Type | Description |
_links  |
enabled  |
boolean  |
The SAML service provider is enabled. Valid for PATCH and GET operations only.  |
Example request
      "href": "/api/resourcelink"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
12320791  |
SAML can only be disabled using the console or a SAML-authenticated application.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
certificate
security_saml_sp
_links  |
enabled  |
boolean  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
