Update key managers
PATCH /security/key-managers/{uuid}
Updates a key manager.
Related ONTAP commands
security key-manager external modify -
security key-manager onboard update-passphrase
Learn more
uuid |
string |
path |
True |
Key manager UUID |
Request Body
| Name | Type | Description |
_links |
external |
Configures external key management |
onboard |
Configures onboard key management. After configuring onboard key management, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
svm |
uuid |
string |
Example request
"href": "/api/resourcelink"
"external": {
"client_certificate": {
"server_ca_certificates": [
"servers": [
"timeout": 60,
"username": "username"
"onboard": {
"existing_passphrase": "The cluster password of length 32-256 ASCII characters.",
"passphrase": "The cluster password of length 32-256 ASCII characters."
"scope": "string",
"svm": {
"name": "svm1",
"uuid": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536822 |
Multitenant key management is not supported in the current cluster version. |
65536828 |
External key management is not enabled for the SVM. |
65536821 |
Certificate is not installed. |
65536850 |
The new client certificate public or private keys are different from the existing client certificate. |
65536852 |
Failed to query supported KMIP protocol versions. |
65536917 |
Updating an onboard passhrase requires both new and existing cluster passphrase. |
65536150 |
New passphrase is same as old passphrase. |
65536139 |
The existing passphrase value provided does not match the configured passphrase. |
65536404 |
Passphrase does not match the accepted length. |
65536802 |
Passphrase does not match the accepted length in common criteria mode. |
65536408 |
Passphrase update failed on some nodes. |
65536407 |
65536406 |
Change of passphrase failed. |
66060338 |
Failed to establish secure connection for a key management server due to incorrect server_ca certificates. |
66060339 |
Failed to establish secure connection for a key management server due to incorrect client certificates. |
66060340 |
Failed to establish secure connection for a key management server due to Cryptsoft error. |
66060341 |
Failed to establish secure connection for a key management server due to network configuration issues. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
client_certificate
Client certificate
_links |
uuid |
string |
Certificate UUID |
Security certificate object reference
_links |
uuid |
string |
Certificate UUID |
key_server_readcreate
_links |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. |
username |
string |
Username credentials for connecting with the key server. |
external
client_certificate |
Client certificate |
server_ca_certificates |
array[server_ca_certificates] |
The UUIDs of the server CA certificates already installed in the cluster or SVM. The array of certificates are common for all the keyservers per SVM. |
servers |
array[key_server_readcreate] |
The set of external key servers. |
onboard
enabled |
boolean |
Is the onboard key manager enabled? |
existing_passphrase |
string |
The cluster-wide passphrase. This is not audited. |
passphrase |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
security_key_manager
_links |
external |
onboard |
scope |
string |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
