Update a primary key server
PATCH /security/key-managers/{uuid}/key-servers/{server}
Updates a key server.
Related ONTAP commands
security key-manager external modify-server
uuid  |
string  |
path  |
True  |
External key manager UUID  |
server  |
string  |
path  |
True  |
Key server configured in the external key manager  |
Request Body
| Name | Type | Description |
_links  |
password  |
string  |
Password credentials for connecting with the key server. This is not audited.  |
timeout  |
integer  |
I/O timeout in seconds for communicating with the key server.  |
username  |
string  |
KMIP username credentials for connecting with the key server.  |
Example request
      "href": "/api/resourcelink"
  "password": "password",
  "timeout": 60,
  "username": "username"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536822  |
Multitenant key management is not supported in the current cluster version.  |
65536828  |
External key management is not enabled for the SVM.  |
65536824  |
Multitenant key management is not supported in MetroCluster configurations.  |
65536843  |
Key management server is not configured for the SVM.  |
65536846  |
Missing password.  |
65536845  |
Missing username.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
records
_links  |
password  |
string  |
timeout  |
integer  |
username  |
string  |
key_server
_links  |
password  |
string  |
timeout  |
integer  |
username  |
string  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
