Update the SnapMirror policy
PATCH /snapmirror/policies/{uuid}
Updates the SnapMirror policy.
Important notes
The properties "transfer_schedule" and "throttle" can be modified only if all the SnapMirror relationships associated with the specified SnapMirror policy have the same values.
The properties "retention.label" and "retention.count" are mandatory if "retention" is provided in the input. The provided "retention.label" is the final list and is replaced with the existing values.
The value of the "identity_preservation" property cannot be changed if the SnapMirror relationships associated with the policy have different identity_preservation configurations.
If the SnapMirror policy "identity_preservation" value matches the "identity_preservation" value of the associated SnapMirror relationships, then the "identity_preservation" value can be changed from a higher "identity_preservation" threshold value to a lower "identity_preservation" threshold value but not vice-versa. For example, the threshold value of the "identity_preservation" property can be changed from "full" to "exclude_network_config" to "exclude_network_and_protocol_config", but could not be increased from "exclude_network_and_protocol_config" to "exclude_network_config" to "full".
Related ONTAP commands
snapmirror policy modify
Example
Updating the "retention" property
PATCH "/api/snapmirror/policies/fe65686d-00dc-11e9-b5fb-0050568e3f83" '{"retention" : {"label" : ["sm_created", "lab2"], "count": ["1","2"], "creation_schedule": {"name": ["weekly"]}}}'
Updating "transfer_schedule", "throttle", and "identity_preservation" properties
PATCH "/api/snapmirror/policies/8aef950b-3bef-11e9-80ac-0050568ea591" '{"transfer_schedule.name" : "weekly", "throttle" : "100", "identity_preservation":"exclude_network_and_protocol_config"}'
Learn more
uuid |
string |
path |
True |
Policy UUID |
Request Body
| Name | Type | Description |
_links |
comment |
string |
Comment associated with the policy. |
identity_preservation |
string |
Specifies which configuration of the source SVM is replicated to destination. This field is applicable only for SVM data protection and async policies. |
network_compression_enabled |
boolean |
Specifies whether network compression is enabled for transfers. This is applicable only to async policies. |
retention |
array[snapmirror_policy_rule] |
Policy on Snapshot copy retention. This is applicable only to async policies. |
scope |
string |
Set to "svm" for policies owned by an SVM, otherwise set to "cluster". |
sync_common_snapshot_schedule |
Schedule used to create common Snapshot copies for synchronous relationships. |
throttle |
integer |
Throttle in KB/s. Default to unlimited. |
transfer_schedule |
The schedule used to update asynchronous relationships. |
uuid |
string |
Example request
"href": "/api/resourcelink"
"comment": "string",
"identity_preservation": "string",
"retention": [
"count": 7,
"name": "weekly",
"label": "hourly",
"prefix": "string"
"scope": "string",
"sync_common_snapshot_schedule": {
"name": "weekly",
"throttle": 0,
"transfer_schedule": {
"name": "weekly",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
13303842 |
Invalid SnapMirror policy type |
13303843 |
Conflicting values between SnapMirror policy and SnapMirror relationships for either 'transfer_schedule, throttle or identity_preservation' properties |
13303850 |
Invalid input parameter |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
creation_schedule
Schedule used to create Snapshot copies on the destination for long term retention.
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
SnapMirror policy rule for retention.
count |
integer |
Number of Snapshot copies to be kept for retention. |
creation_schedule |
Schedule used to create Snapshot copies on the destination for long term retention. |
label |
string |
Snapshot copy label |
prefix |
string |
Specifies the prefix for the Snapshot copy name to be created as per the schedule. If no value is specified, then the label is used as the prefix. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
transfer_schedule
_links |
name |
string |
Job schedule name |
uuid |
string |
Job schedule UUID |
snapmirror_policy
SnapMirror policy information
_links |
comment |
string |
string |
boolean |
retention |
scope |
string |
throttle |
integer |
transfer_schedule |
uuid |
string |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
