Updates the aggregate specified by the uuid with the properties in the body this request starts a job and returns a link to that job
storage aggregate mirror -
storage aggregate modify -
storage aggregate relocation start -
storage aggregate rename
learn more
doc /storage/aggregates](#docs-storage-storage_aggregates)
PATCH /storage/aggregates/{uuid}
Updates the aggregate specified by the UUID with the properties in the body. This request starts a job and returns a link to that job.
Related ONTAP commands
storage aggregate add-disks -
Learn more
uuid |
string |
path |
True |
Aggregate UUID |
disk_size |
integer |
query |
False |
If set, PATCH only selects disks of the specified size. |
Request Body
| Name | Type | Description |
_links |
block_storage |
Configuration information for the locally attached portion of the aggregate. When a cloud store is also used by this aggregate, this is referred to as the performance tier. |
cloud_storage |
Configuration information for the cloud storage portion of the aggregate. This is referred to as the capacity tier. |
create_time |
string |
Timestamp of aggregate creation |
data_encryption |
dr_home_node |
Node where the aggregate belongs after disaster recovery. The value for this field might differ from the 'node' field during switchover. |
home_node |
Node where the aggregate belongs after giveback. The value for this field might differ from the value of the 'node' field during takeover. |
name |
string |
Aggregate name |
node |
Node where the aggregate currently resides. |
space |
state |
string |
Operational state of the aggregate |
uuid |
string |
Aggregate UUID |
Example request
"href": "/api/resourcelink"
"block_storage": {
"hybrid_cache": {
"disk_count": 6,
"raid_type": "string",
"size": 1612709888,
"used": 26501122
"mirror": {
"enabled": "",
"state": "string"
"plexes": [
"name": "plex0"
"primary": {
"disk_count": 8,
"raid_size": 16,
"cloud_storage": {
"stores": [
"cloud_store": {
"name": "store1",
"used": 0
"create_time": "2018-01-01 12:00:00 -0400",
"dr_home_node": {
"name": "node1",
"home_node": {
"name": "node1",
"name": "node1_aggr_1",
"node": {
"name": "node1",
"space": {
"block_storage": {
"available": 10156560384,
"full_threshold_percent": 0,
"inactive_user_data": 304448,
"size": 10156769280,
"used": 2088960
"cloud_storage": {
"used": 402743264
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"efficiency_without_snapshots": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"footprint": 608896
"state": "string",
"uuid": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
787092 |
The target field cannot be specified for this operation. |
787169 |
Only one field can be modified per operation. |
786439 |
An aggregate already uses the specified name. |
786468 |
VLDB is offline. |
786771 |
Aggregate does not exist. |
786458 |
Failed to rename aggregate. |
786435 |
Internal Error. Failed to create a communication handle. |
786867 |
Specified aggregate resides on the remote cluster. |
786472 |
Node that hosts the aggregate is offline. |
786434 |
Cannot connect to node where the aggregate resides. |
786730 |
Internal Error |
786911 |
Not every node in the cluster has the Data ONTAP version required for the feature. |
787170 |
Failed to patch the "block_storage.primary.disk_count" because the disk count specified is smaller than existing disk count. |
786965 |
Spare Selection in userspace failed. |
786456 |
Failed to add disks to aggregate. |
787046 |
Mirroring of a FabricPool is not allowed. |
786808 |
Aggregate mirror failed. |
786479 |
Cannot find node ID for the node. |
787144 |
Aggregate is not a FabricPool. |
786787 |
Aggregate is not online. |
787156 |
Modifying the attributes of mirror object store is not allowed. |
786923 |
This operation is disallowed during pre-commit phase of 7-mode to clustered Data ONTAP transition. |
786924 |
Internal Error for an aggregate that is in pre-commit phase of a 7-mode to clustered Data ONTAP transition. |
786955 |
Modifying raidtype to raid_tec requires a minimum of six disks in the RAID Group. |
786956 |
Modifying raidtype to raid_dp requires a minimum of four disks in the RAID Group. |
786447 |
Failed to modify aggregate. |
787178 |
Unmirroring an aggregate with a PATCH operation is not supported. |
460777 |
Failed to get information on the job. |
2425736 |
No matching node found for the UUID provided. |
26542101 |
Unable to contact source node. |
26542102 |
Unable to contact destination node. |
26542084 |
Source node is at higher Data ONTAP version than destination node. |
26542083 |
Destination node is at higher Data ONTAP version than source node. |
26542120 |
A Vserver migrate operation is in progress. When the migrate operation completes, try the operation again. |
26542121 |
A MetroCluster disaster recovery operation is in progress. When the recovery operation completes, try the operation again. |
26542097 |
Unable to get D-blade ID of destination. |
262247 |
The value is invalid for the field. |
13108106 |
Cannot run aggregate relocation because volume expand is in progress. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
hybrid_cache
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs.
disk_count |
integer |
Number of disks used in the cache tier of the aggregate. Only provided when hybrid_cache.enabled is 'true'. |
enabled |
boolean |
Aggregate uses HDDs with SSDs as a cache |
raid_type |
string |
RAID type for SSD cache of the aggregate. Only provided when hybrid_cache.enabled is 'true'. |
size |
integer |
Total usable space in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'. |
used |
integer |
Space used in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'. |
mirror
enabled |
boolean |
Aggregate is SyncMirror protected |
state |
string |
plex_reference
Plex
_links |
name |
string |
primary
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details.
disk_count |
integer |
Number of disks used in the aggregate. This includes parity disks, but excludes disks in the hybrid cache. |
raid_size |
integer |
Option to specify the maximum number of disks that can be included in a RAID group. |
raid_type |
string |
RAID type of the aggregate. |
block_storage
hybrid_cache |
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs. |
mirror |
plexes |
array[plex_reference] |
Plex reference for each plex in the aggregate. |
primary |
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details. |
cloud_store
Cloud store
_links |
name |
string |
uuid |
string |
cloud_storage_tier
cloud_store |
Cloud store |
used |
integer |
Capacity used in bytes in the cloud store by this aggregate. This is a cached value calculated every 5 minutes. |
cloud_storage
attach_eligible |
boolean |
Aggregate is eligible for a cloud store to be attached. |
stores |
array[cloud_storage_tier] |
Configuration information for each cloud storage portion of the aggregate. |
tiering_fullness_threshold |
integer |
The percentage of space in the performance tier that must be used before data is tiered out to the cloud store. Only valid for PATCH operations. |
data_encryption
drive_protection_enabled |
boolean |
Aggregate uses self-encrypting drives with data protection enabled. |
software_encryption_enabled |
boolean |
NetApp Aggregate Encryption enabled. All data in the aggregate is encrypted. |
dr_home_node
name |
string |
uuid |
string |
home_node
_links |
name |
string |
uuid |
string |
node
_links |
name |
string |
uuid |
string |
block_storage
available |
integer |
Space available in bytes |
full_threshold_percent |
integer |
The aggregate used percentage at which 'monitor.volume.full' EMS is generated. |
inactive_user_data |
integer |
The size that is physically used in the block storage and has a cold temperature, in bytes. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data or **. |
size |
integer |
Total usable space in bytes, not including WAFL reserve and aggregate Snapshot copy reserve. |
used |
integer |
Space used or reserved in bytes. Includes volume guarantees and aggregate metadata. |
cloud_storage
used |
integer |
Used space in bytes in the cloud store. Only applicable for aggregate with a cloud store tier. |
efficiency
Storage efficiency
logical_used |
integer |
Logical used |
ratio |
number |
Data reduction ratio (logical_used / used) |
savings |
integer |
Space saved by storage efficiencies (logical_used - used) |
Storage efficiency that does not include the savings provided by Snapshot copies
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
space
block_storage |
cloud_storage |
efficiency |
Storage efficiency |
efficiency_without_snapshots |
Storage efficiency that does not include the savings provided by Snapshot copies |
footprint |
integer |
A summation of volume footprints (including volume guarantees), in bytes. This includes all of the volume footprints in the block_storage tier and the cloud_storage tier. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
aggregate
_links |
block_storage |
cloud_storage |
create_time |
string |
data_encryption |
dr_home_node |
home_node |
name |
string |
Aggregate name |
node |
space |
state |
string |
uuid |
string |
Aggregate UUID |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
