REST API reference
Updates a snapshot copy policy
  • snapshot policy modify-schedule
  • snapshot policy add-schedule # learn more
  • [doc /storage/snapshot-policies](#docs-storage-storage_snapshot-policies)
PATCH /storage/snapshot-policies/{uuid}
Updates a Snapshot copy policy
uuid
string
path
True
Snapshot policy UUID
Request Body
Name Type Description
_links
_links
comment
string
A comment associated with the Snapshot copy policy.
enabled
boolean
Is the Snapshot copy policy enabled?
scope
string
Set to "svm" when the request is on a data SVM, otherwise set to "cluster".
uuid
string
Example request
      "href": "/api/resourcelink"
  "comment": "string",
  "enabled": 1,
  "scope": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Code
Error Code Description
1638414
Cannot enable policy. Reason: Specified schedule not found.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
schedule
name
string
Schedule at which Snapshot copies are captured on the volume. Some common schedules already defined in the system are hourly, daily, weekly, at 15 minute intervals, and at 5 minute intervals. Snapshot copy policies with custom schedules can be referenced.
copies
count
integer
The number of Snapshot copies to maintain for this schedule.
prefix
string
The prefix to use while creating Snapshot copies at regular intervals.
schedule
schedule
snapmirror_label
string
Label for SnapMirror operations
svm
_links
_links
name
string
The name of the SVM.
uuid
string
snapshot_policy
The Snapshot copy policy object is associated with a read-write volume used to create and delete Snapshot copies at regular intervals.
_links
_links
comment
string
enabled
boolean
scope
string
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
