REST API reference
Updates the ems configuration
learn more
  • [doc /support/ems](#docs-support-support_ems)
PATCH /support/ems
Updates the EMS configuration.
  • event config modify
Learn more
Request Body
Name Type Description
_links
_links
mail_from
string
Mail from
mail_server
string
Mail server (SMTP)
proxy_password
string
Password for HTTP/HTTPS proxy
proxy_url
string
HTTP/HTTPS proxy URL
proxy_user
string
User name for HTTP/HTTPS proxy
Example request
      "href": "/api/resourcelink"
  "mail_from": "administrator@mycompany.com",
  "mail_server": "mail@mycompany.com",
  "proxy_password": "password",
  "proxy_url": "https://proxyserver.mycompany.com",
  "proxy_user": "proxy_user"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
983123
The validation of the mail server provided failed
983136
The proxy URL cannot contain a username or password
983137
The proxy URLprovided is invalid
983139
The IPv6 proxy URL provided is invalid
983140
The proxy URL provided contains an invalid scheme. Supported schemes are 'http' or 'https'
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
ems_config
_links
_links
mail_from
string
Mail from
mail_server
string
Mail server (SMTP)
proxy_password
string
proxy_url
string
proxy_user
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
