Update SVM properties
PATCH /svm/svms/{uuid}
Updates one or more of the following properties of an individual SVM: SVM name, SVM default volume language code, SVM comment, and SVM state.
Related ONTAP commands
vserver modify -
vserver rename -
vserver start -
vserver stop
Stops an SVM and updates the "comment" field for an individual SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"state":"stopped", "comment":"This SVM is stopped."}'
Starts an SVM and updates the "comment" field for an individual SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"state":"running", "comment":"This SVM is running."}'
Updates the "language" field for an individual SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"language":"en.UTF-8"}'
Updates the "name" field for an SVM or renames the SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"name":"svm_new"}'
Updates the aggregates for an individual SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"aggregates":{"name":["aggr1","aggr2","aggr3"]}}'
Updates the Snapshot copy policy for an individual SVM
  PATCH "/api/svm/svms/f16f0935-5281-11e8-b94d-005056b46485" '{"snapshot_policy":{"name":"custom1"}}'
Learn more
uuid  |
string  |
path  |
True  |
Filter by UUID  |
return_timeout  |
integer  |
query  |
False  |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202.  |
Request Body
| Name | Type | Description |
_links  |
aggregates  |
array[aggregates]  |
List of allowed aggregates for SVM volumes. An administrator is allowed to create volumes on these aggregates.  |
comment  |
string  |
Comment  |
ip_interfaces  |
array[ip_interface_svm]  |
IP interfaces for the SVM  |
language  |
string  |
Default volume language code. UTF-8 encoded languages are valid in POST or PATCH. Non UTF-8 language encodings are for backward compatibility and are not valid input for POST and PATCH requests.  |
name  |
string  |
The name of the SVM.  |
snapshot_policy  |
This is a reference to the Snapshot copy policy.  |
state  |
string  |
SVM State  |
uuid  |
string  |
The unique identifier of the SVM.  |
Example request
      "href": "/api/resourcelink"
  "aggregates": [
      "name": "aggr1",
  "comment": "string",
  "ip_interfaces": [
  "language": "c.utf_8",
  "name": "svm1",
  "snapshot_policy": {
    "name": "default",
  "state": "running",
Status: 202, Accepted
job  |
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
13434880  |
Failed to modify SVM parameters.  |
13434881  |
Failed to rename SVM.  |
13434883  |
SVM parameters except name modified successfully.  |
13434885  |
Non-UTF8 language(s) not supported.  |
13434886  |
Invalid Snapshot copy policy.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
aggregates
Aggregate
_links  |
name  |
string  |
uuid  |
string  |
ad_domain
cifs
_links  |
ad_domain  |
enabled  |
boolean  |
Specifies whether or not the CIFS service is administratively enabled.  |
name  |
string  |
The NetBIOS name of the CIFS server.  |
dns
_links  |
domains  |
array[string]  |
A list of DNS domains. Domain names have the following requirements:
servers  |
array[string]  |
The list of IP addresses of the DNS servers. Addresses can be either IPv4 or IPv6 addresses.  |
fcp
_links  |
enabled  |
boolean  |
Enable Fiber Channel Protocol (FCP)? Setting to true creates a service if not already created.  |
ip
IP information
broadcast_domain
Broadcast domain UUID along with a readable name.
_links  |
name  |
string  |
Name of the broadcast domain, scoped to its IPspace  |
uuid  |
string  |
Broadcast domain UUID  |
home_node
_links  |
name  |
string  |
uuid  |
string  |
location
Home_node is optional.
broadcast_domain  |
Broadcast domain UUID along with a readable name.  |
home_node  |
ip_interface_svm
Interface parameters. Name and home_node are optional.
_links  |
ip  |
IP information  |
uuid  |
string  |
The UUID that uniquely identifies the interface.  |
ipspace
Either the UUID or name may be supplied on input.
_links  |
name  |
string  |
IPspace name  |
uuid  |
string  |
IPspace UUID  |
iscsi
_links  |
enabled  |
boolean  |
Enable iSCSI? Setting to true creates a service if not already created.  |
ldap
ad_domain  |
string  |
This parameter specifies the name of the Active Directory domain
used to discover LDAP servers for use by this client.
This is mutually exclusive with   |
base_dn  |
string  |
Specifies the default base DN for all searches.  |
bind_dn  |
string  |
Specifies the user that binds to the LDAP servers. SVM API supports anonymous binding. For Simple and SASL LDAP binding, use the LDAP API endpoint.  |
enabled  |
boolean  |
Enable LDAP? Setting to true creates a configuration if not already created.  |
servers  |
array[string]  |
nfs
_links  |
enabled  |
boolean  |
Enable NFS? Setting to true creates a service if not already created.  |
nis
_links  |
domain  |
string  |
The NIS domain to which this configuration belongs.  |
enabled  |
boolean  |
Enable NIS? Setting to true creates a configuration if not already created.  |
servers  |
array[string]  |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration.  |
nsswitch
Name Service Switch Configuration
group  |
array[string]  |
Group sources  |
hosts  |
array[string]  |
Host sources  |
namemap  |
array[string]  |
NameMap sources  |
netgroup  |
array[string]  |
NetGroup sources  |
passwd  |
array[string]  |
Password sources  |
nvme
_links  |
enabled  |
boolean  |
Enable NVMe? Setting to true creates a service if not already created.  |
ip_info
IP information
address  |
string  |
IPv4 or IPv6 address  |
family  |
string  |
IPv4 or IPv6  |
netmask  |
string  |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length.  |
network_route_for_svm
destination  |
IP information  |
gateway  |
string  |
The IP address of the gateway router leading to the destination.  |
snapshot_policy
_links  |
name  |
string  |
uuid  |
string  |
svm
_links  |
aggregates  |
array[aggregates]  |
comment  |
string  |
Comment  |
ip_interfaces  |
language  |
string  |
name  |
string  |
snapshot_policy  |
state  |
string  |
SVM State  |
uuid  |
string  |
job_link
_links  |
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
