Restore a snapshot copy of an application component<br/>
learn more
doc /application/applications/{applicationuuid}/snapshots](#docs-application-application_applications_{applicationuuid}_snapshots) -
post /application/applications/{applicationuuid}/snapshots/{uuid}/restore](#operations-application-application_snapshot_restore) -
doc /application](#docs-application-overview) -
doc asynchronous operations](#docs-docs-synchronous-and-asynchronous-operations)
POST /application/applications/{application.uuid}/components/{component.uuid}/snapshots/{uuid}/restore
Restore a Snapshot copy of an application component.
This endpoint is only supported for Maxdata template applications.
Component Snapshot copies are essentially more granular application Snapshot copies. There is no difference beyond the scope of the operation.
Learn more
application.uuid |
string |
path |
True |
component.uuid |
string |
path |
True |
uuid |
string |
path |
True |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"href": "/api/resourcelink"
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
