Add a node or nodes to a cluster
POST /cluster/nodes
Adds a node or nodes to the cluster
Required properties
cluster_interface.ip.address
Learn more
Request Body
| Name | Type | Description |
_links |
cluster_interface |
The cluster network IP address of the node to be added. |
cluster_interfaces |
array[cluster_interfaces] |
controller |
Controller information |
date |
string |
Specifies the ISO-8601 format date and time on the node. |
ha |
location |
string |
management_interface |
The management interface of the node to be added. The netmask is set based on the management interface of the cluster or the managment interfaces of other nodes. |
management_interfaces |
array[management_interfaces] |
membership |
string |
Possible values:
model |
string |
name |
string |
serial_number |
string |
service_processor |
uptime |
integer |
The total time, in seconds, that the node has been up. |
uuid |
string |
version |
This returns the cluster version information. When the cluster has more than one node, the cluster version is equivalent to the lowest of generation, major, and minor versions on all nodes. |
Example request
"href": "/api/resourcelink"
"cluster_interface": {
"ip": {
"address": "10.10.10.7"
"cluster_interfaces": [
"ip": {
"name": "lif1",
"controller": {
"flash_cache": [
"capacity": 1024000000000,
"firmware_version": "NA05",
"hardware_revision": "A1",
"model": "X1970A",
"part_number": "119-00207",
"serial_number": "A22P5061550000187",
"slot": "6-1",
"state": "string"
"frus": [
"id": 0,
"state": "string",
"type": "string"
"over_temperature": "string"
"date": "2017-01-25 11:20:13 +0400",
"ha": {
"partners": [
"name": "node1",
"location": "rack 2 row 5",
"management_interface": {
"ip": {
"management_interfaces": [
"ip": {
"name": "lif1",
"membership": "string",
"model": "FAS3070",
"name": "node-01",
"serial_number": "4048820-60-9",
"service_processor": {
"dhcp_enabled": null,
"firmware_version": "string",
"ipv4_interface": {
"address": "10.10.10.7",
"gateway": "10.1.1.1",
"netmask": "24"
"link_status": "string",
"mac_address": "string",
"state": "string"
"uptime": 300536,
"uuid": "4ea7a442-86d1-11e0-ae1c-123478563412",
"version": {
"full": "NetApp Release 9.4.0: Sun Nov 05 18:20:57 UTC 2017",
"generation": 9,
"major": 4,
"minor": 0
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
131727360 |
A node cannot be added to the cluster. This is a generic code, see response message for details. |
262245 |
The value provided was invalid. |
1179817 |
The IP address, netmask, and gateway must all be provided for cluster manangement interface. |
1179813 |
Fields set for one node must be set for all nodes. |
1179818 |
The IP address and gateway must be of the same family. |
1179821 |
An IP address and netmask conflicts with an existing entry. |
1179795 |
A node being added is already in the cluster. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
node_setup_ip
The IP configuration for cluster setup.
address |
string |
IPv4 or IPv6 address |
cluster_interface
ip |
The IP configuration for cluster setup. |
ip
IP information
address |
string |
cluster_interfaces
Network interface
_links |
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
flash_cache
capacity |
integer |
Size in bytes |
firmware_version |
string |
hardware_revision |
string |
model |
string |
part_number |
string |
serial_number |
string |
slot |
string |
state |
string |
frus
id |
integer |
state |
string |
type |
string |
controller
flash_cache |
array[flash_cache] |
A list of Flash-Cache devices. Only returned when requested by name. |
frus |
array[frus] |
A list of frus in the node. Only returned when requested by name. |
over_temperature |
string |
Specifies whether the hardware is currently operating outside of its recommended temperature range. The hardware shuts down if the temperature exceeds critical thresholds. |
partners
_links |
name |
string |
uuid |
string |
ha
auto_giveback |
boolean |
Specifies whether giveback is automatically initiated when the node that owns the storage is ready. |
enabled |
boolean |
Specifies whether or not storage failover is enabled. |
partners |
array[partners] |
The nodes in this node's High Availability (HA) group. |
ip |
Network interface
_links |
ip |
IP information |
name |
string |
uuid |
string |
ipv4_interface
Object to setup an interface along with its default router.
address |
string |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
ipv6_interface
address |
string |
gateway |
string |
netmask |
string |
service_processor
firmware_version |
string |
The version of firmware installed. |
ipv4_interface |
Object to setup an interface along with its default router. |
link_status |
string |
mac_address |
string |
state |
string |
version
full |
string |
The full cluster version string. |
generation |
integer |
The generation portion of the version. |
major |
integer |
The major portion of the version. |
minor |
integer |
The minor portion of the version. |
node
Complete node information
_links |
cluster_interface |
controller |
date |
string |
ha |
location |
string |
membership |
string |
Possible values:
model |
string |
name |
string |
serial_number |
string |
service_processor |
uptime |
integer |
uuid |
string |
version |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
