Create a peering relationship
POST /cluster/peers
Creates a peering relationship and, optionally, the IP interfaces it will use. There are two ways to create a peering relationship.
Provide remote IP
Here the user provides the remote IP address. Creating a new cluster peer relationship with a specific remote cluster requires at least one remote intercluster IP address from that cluster.
Required properties
remote.ip_addresses- Addresses of the remote peers. The local peer must be able to reach and connect to these addresses for the request to succeed in creating a peer. -
Either set
generate_passphraseto true or provide a passphrase in the body of the request; only one of them is required.
Optional properties
The following fields are optional for a POST on /cluster/peer/. All fields must follow the structure in the cluster peer API definition.
name- Name of the peering relationship. -
passphrase- User generated passphrase for use in authentication. -
generate_passphrase(true/false) - When this option is true, ONTAP automatically generates a passphrase to authenticate cluster peers. -
ipspace- IPspace of the local intercluster LIFs. Assumes Default IPspace if not provided. -
initial_allowed_svms- the local SVMs allowed to peer with the peer cluster's SVMs. This list can be modified until the remote cluster accepts this cluster peering relationship. -
local_network- fields to create a local intercluster LIF. See section on "Creating local intercluster lifs". -
expiry_time- Duration in ISO 8601 format for which the user-supplied or auto-generated passphrase is valid. Expiration time must not be greater than seven days into the future. ISO 8601 duration format is "PnDTnHnMnS" or "PnW" where n is a positive integer. The nD, nH, nM and nS fields can be dropped if zero. "P" should always be present and "T" should be present if there are any hours, minutes or seconds fields. -
encryption_proposed(none/tls-psk) - Encryption mechanism of the communication channel between the two peers.
Do not provide remote IP
This method is used when the remote IP address is not provided. This method is used when the filer is ready to accept peering request from foreign clusters.
Required properties
generate_passphrase(true) - This option must be set to true. ONTAP automatically generates a passphrase to authenticate cluster peers. Either set generate_passphrase to true or provide a passphrase in the body of the request; only one of them is required.
Optional properties
name- Name of the remote peer. -
initial_allowed_svms- Local SVMs allowed to peer with the peer cluster's SVMs. This list can be modified until the remote cluster accepts this cluster peering relationship. -
local_network- Fields to create a local intercluster LIF. See section on "Creating local intercluster lifs". -
Additional information
As with creating a cluster peer through the CLI, the combinations of options must be valid in order for the create operation to succeed. The following list shows the combinations that will succeed and those that will fail:
a passphrase only (fail)
a peer IP address (fail)
a passphrase with an expiration time > 7 days into the future (fail)
peer IP address and a passphrase (OK)
generate_passphrase=true (OK)
any proposed encryption protocol (OK)
an IPspace name or UUID (OK)
a passphrase, peer IP address, and any proposed encryption protocol (OK)
a non empty list initial allowed vserver peer names or UUIDs. (OK)
Learn more
Request Body
| Name | Type | Description |
_links |
authentication |
encryption |
initial_allowed_svms |
array[initial_allowed_svms] |
The local SVMs allowed to peer with the peer cluster's SVMs. This list can be modified until the remote cluster accepts this cluster peering relationship. |
ipspace |
The IPspace of the local intercluster LIFs |
local_network |
Cluster peering requires an intercluster LIF on each local node. These can be optionally created by specifying a list of IP addresses corresponding to each node. |
name |
string |
Optional name for the cluster peer relationship. By default it is the name of the remote cluster. |
remote |
status |
uuid |
string |
UUID of the cluster peer relationship. For anonymous cluster peer offers, the UUID will change when the remote cluster accepts the relationship. |
Example request
"interfaces": {
"href": "/api/resourcelink"
"authentication": {
"expiry_time": "P1DT2H3M4S or '2017-01-25T11:20:13Z'",
"in_use": "string",
"passphrase": "string",
"state": "string"
"encryption": {
"proposed": "string",
"state": "string"
"initial_allowed_svms": [
"name": "svm1",
"ipspace": {
"name": "exchange",
"local_network": {
"broadcast_domain": "bd1",
"gateway": "10.1.1.1",
"interfaces": [
"ip_address": "10.10.10.7"
"netmask": "255.255.0.0"
"name": "cluster2",
"remote": {
"ip_addresses": [
"10.10.10.7"
"name": "cluster2",
"serial_number": "4048820-60-9"
"status": {
"state": "available",
"update_time": "2017-01-25 11:20:13 UTC"
Status: 201, Created
_links |
authentication |
ip_address |
string |
IPv4 or IPv6 address |
name |
string |
Optional name for the cluster peer relationship. By default it is the name of the remote cluster, or a temporary name may be autogenerated for anonymous cluster peer offers. |
"authentication": {
"expiry_time": "2017-01-25 11:20:13 UTC",
"ip_address": "10.10.10.7",
"name": "cluster2"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
4656069 |
Specifying a passphrase without remote IP addresses is not supported. |
4656070 |
The encryption protocol is meaningful only with authenticated cluster peer relationships. |
4656071 |
Cannot peer with a cluster bearing the same name as the local cluster. |
4656072 |
The name must conform to the same rules as a cluster name. |
4656074 |
Cannot check whether all nodes of this cluster support encryption. |
4656077 |
Specify either remote IP addresses or generate_passphrase. |
4656075 |
Cannot specify encryption: this operation requires an ECV of 9.6.0 or later. |
4656079 |
No cluster nodes were found. Check your cluster configuration. |
4656085 |
Cannot create an intercluster LIF with an empty list of local IP addresses. |
4656087 |
The number of local intercluster IP addresses must be less than or equal to the number of available nodes. |
4656086 |
Creating an intercluster LIF requires a broadcast domain that is in use within the IPspace. |
4653365 |
IPspaces are unavailable with cluster peering: {ipspace}. |
4656088 |
Found no ports matching the IPspace and the broadcast domain. |
4656089 |
Found no matching entry for IPspace. |
4656090 |
The given IPspace differs from the IPspace entry found. |
4656091 |
Creating an intercluster LIF requires a network mask or a network mask length. |
4656081 |
Creating an intercluster LIF requires a list of local IP addresses. |
1966366 |
The System SVM of the cluster IPspace hosts Cluster LIFs only. |
4656096 |
Creating an intercluster LIF requires an IPv4 or IPv6 address of the default router. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
interfaces |
self |
authentication
expiry_time |
string |
The time when the passphrase will expire, in ISO 8601 duration format or date and time format. The default is 1 hour. |
generate_passphrase |
boolean |
Auto generate a passphrase when true. |
in_use |
string |
passphrase |
string |
A password to authenticate the cluster peer relationship. |
state |
string |
encryption
proposed |
string |
state |
string |
_links
self |
_links |
name |
string |
The name of the SVM. |
uuid |
string |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
interfaces
ip_address |
string |
local_network
broadcast_domain |
string |
Broadcast domain that is in use within the IPspace. |
gateway |
string |
The IPv4 or IPv6 address of the default router. |
interfaces |
array[interfaces] |
netmask |
string |
IPv4 mask or netmask length. |
remote
ip_addresses |
array[string] |
The IPv4 addresses, IPv6 addresses, or hostnames of the peers. |
name |
string |
The name of the remote cluster. |
serial_number |
string |
The serial number of the remote cluster. |
status
state |
string |
update_time |
string |
The last time the state was updated. |
cluster_peer
_links |
authentication |
encryption |
ipspace |
local_network |
name |
string |
remote |
status |
uuid |
string |
authentication
expiry_time |
string |
The date and time the passphrase will expire. The default expiry time is one hour. |
passphrase |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
