Create the NIS domain and server configuration for a data SVM
POST /name-services/nis
Creates an NIS domain and server confguration for a data SVM. NIS configuration for the cluster is managed via /api/security/authentication/cluster/nis .
Important notes
Each SVM can have one NIS domain configuration.
Multiple SVMs can be configured with the same NIS domain. Specify the NIS domain and NIS servers as input.Domain name and servers fields cannot be empty.
Both FQDNs and IP addresses are supported for the servers field.
IPv6 must be enabled if IPv6 family addresses are specified in the servers field.
A maximum of ten NIS servers are supported.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the NIS configuration. -
domain- NIS domain to which the configuration belongs. -
servers- List of NIS server IP addresses.
Related ONTAP commands
vserver services name-service nis-domain create
Learn more
Request Body
| Name | Type | Description |
_links |
bound_servers |
array[string] |
domain |
string |
The NIS domain to which this configuration belongs. |
servers |
array[string] |
A list of hostnames or IP addresses of NIS servers used by the NIS domain configuration. |
svm |
Example request
"href": "/api/resourcelink"
"bound_servers": [
"string"
"domain": "string",
"servers": [
"string"
"svm": {
"name": "svm1",
Status: 201, Created
_links |
num_records |
integer |
Number of NIS domain records. |
records |
array[nis_service] |
"next": {
"records": [
"bound_servers": [
"string"
"domain": "string",
"servers": [
"string"
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1966253 |
IPv6 is not enabled in the cluster |
2621488 |
Invalid SVM context |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name |
3276964 |
NIS domain name or NIS server domain is too long. The maximum supported for domain name is 64 characters and the maximum supported for NIS server domain is 255 characters |
3276933 |
A maximum of 10 NIS servers can be configured per SVM |
23724109 |
DNS resolution failed for one or more specified servers |
23724112 |
DNS resolution failed due to an internal error. Contact technical support if this issue persists |
23724132 |
DNS resolution failed for all the specified servers |
23724130 |
Cannot use an IPv6 name server address because there are no IPv6 LIFs |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
nis_service
_links |
bound_servers |
array[string] |
domain |
string |
servers |
array[string] |
svm |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
