Creates a new broadcast domain<br/>
mtu- maximum transmission unit of the broadcast domain # recommended optional properties -
ipspacenameoripspaceuuid- ipspace the broadcast domain belongs to # default property values if not specified in post, the following default property values are assigned: -
ipspace- default # related ontap commands -
network port broadcast-domain create
learn more
doc /network/ethernet/broadcast-domains](#docs-networking-network_ethernet_broadcast-domains)
POST /network/ethernet/broadcast-domains
Creates a new broadcast domain.
Required properties
name- Name of the broadcast-domain to create. -
mtu- Maximum transmission unit of the broadcast domain.
Recommended optional properties
ipspace.nameoripspace.uuid- IPspace the broadcast domain belongs to.
Default property values
If not specified in POST, the following default property values are assigned:
ipspace- Default
Related ONTAP commands
Learn more
Request Body
| Name | Type | Description |
_links |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input. |
mtu |
integer |
Maximum transmission unit, largest packet size on this network |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
ports |
array[ports] |
Ports that belong to the broadcast domain |
uuid |
string |
Broadcast domain UUID |
Example request
"href": "/api/resourcelink"
"ipspace": {
"name": "exchange",
"mtu": 1500,
"name": "bd1",
"ports": [
"name": "e1b",
"node": {
"name": "node1"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1967082 |
The specified ipspace.name does not match the IPspace name of ipspace.uuid. |
1967102 |
POST operation might have left the configuration in an inconsistent state. Check the configuration. |
1377267 |
The specified IPspace does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
node
name |
string |
Name of node on which the port is located. |
ports
Port UUID along with readable names
_links |
name |
string |
node |
uuid |
string |
broadcast_domain
Set of ports that will receive a broadcast Ethernet packet from any of them
_links |
ipspace |
mtu |
integer |
name |
string |
ports |
array[ports] |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
