Create a new cluster-scoped or SVM-scoped interface
POST /network/ip/interfaces
Creates a new cluster-scoped or svm-scoped interface.
Required properties
name- Name of the interface to create. -
ip.address- IP address for the interface. -
ip.netmask- IP subnet of the interface. -
ipspace.nameoripspace.uuid-
Required for cluster-scoped interfaces.
Optional for svm-scoped interfaces.
svm.nameorsvm.uuid-
Required for a svm-scoped interface.
Invalid for a cluster-scoped interface.
location.home_portorlocation.home_nodeorlocation.broadcast_domain- One of these properties must be set to a value to define where the interface will be located.
Default property values
If not specified in POST, the following default property values are assigned:
scope-
svm if svm parameter is specified.
cluster if svm parameter is not specified
enabled- true -
location.auto_revert- true -
service_policy-
default-data-files if scope is
svm -
default-management if scope is
clusterand IPspace is notCluster -
default-cluster if scope is
svmand IPspace isCluster
failover- Selects the least restrictive failover policy supported by all the services in the service policy.
Related ONTAP commands
network interface create
Learn more
Request Body
| Name | Type | Description |
_links |
enabled |
boolean |
The administrative state of the interface. |
ip |
IP information |
ipspace |
Either the UUID or name must be supplied on POST for cluster-scoped objects. |
location |
Current or home location can be modified. Specifying a port implies a node. Specifying a node allows an appropriate port to be automatically selected. Ports are not valid and not shown for VIP interfaces. For POST, broadcast_domain can be specified alone or with home_node. |
name |
string |
Interface name |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
service_policy |
services |
array[string] |
The services associated with the interface. |
state |
string |
The operational state of the interface. |
svm |
Applies only to SVM-scoped objects. Either the UUID or name must be supplied on POST. |
uuid |
string |
The UUID that uniquely identifies the interface. |
vip |
boolean |
True for a VIP interface, whose location is announced via BGP. |
Example request
"href": "/api/resourcelink"
"ip": {
"address": "10.10.10.7",
"family": "string",
"netmask": "24"
"ipspace": {
"name": "exchange",
"location": {
"broadcast_domain": {
"name": "bd1",
"failover": "string",
"home_port": {
"name": "e1b",
"node": {
"name": "node1"
"name": "dataLif1",
"scope": "string",
"service_policy": {
"name": "default-intercluster",
"services": [
"data_nfs"
"state": "string",
"svm": {
"name": "svm1",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1967127 |
svm.uuid or svm.name must be provided if scope is "svm". |
1967128 |
ipspace.uuid or ipspace.name must be provided if scope is "cluster". |
1967082 |
The specified ipspace.name does not match the IPspace name of ipspace.uuid. |
1967081 |
The specified SVM must exist in the specified IPspace. |
1967120 |
The specified service_policy.name does not match the specified service policy name of service_policy.uuid. |
1967121 |
Invalid service_policy.uuid specified. |
1967122 |
The specified location.broadcast_domain.name does not match the specified broadcast domain name of location.broadcast_domain.uuid. |
1967123 |
The specified IPspace does not match the IPspace name of location.broadcast_domain.uuid. |
1967124 |
Invalid location.broadcast_domain.uuid specified. |
1967106 |
The specified location.home_port.name does not match the specified port name of location.home_port.uuid. |
1967107 |
Invalid location.home_port.uuid specified. |
1967108 |
The specified location.home_node.name does not match the node name of location.home_node.uuid. |
1967109 |
The specified location.home_port.node.name does not match the node name of location.home_node.uuid. |
1967110 |
The specified location.home_port.node.name does not match location.home_node.name. |
1967111 |
Home node must be specified by at least one location.home_node, location.home_port, or location.broadcast_domain field. |
1967112 |
The specified location.home_node.name does not match the node name of location.home_port.uuid. |
1967102 |
POST operation might have left configuration in an inconsistent state. Check the configuration. |
1967137 |
The specified location.broadcast_domain.uuid and location.broadcast_domain.name (and IPspace name) are invalid. |
1967135 |
The specified location.broadcast_domain.uuid is invalid. |
1967136 |
The specified location.broadcast_domain.name (and ipspace name) is invalid. |
1967129 |
The specified location.home_port.uuid is invalid. |
1967130 |
The specified location.home_port.name is invalid. |
1967131 |
The specified location.home_port.uuid and location.home_port.name are invalid. |
1967145 |
The specified location.failover is invalid. |
1967146 |
The specified svm.name is invalid. |
1967147 |
The specified svm.uuid is invalid. |
5373966 |
An iSCSI interface cannot be created in an SVM is configured for NVMe. |
1966140 |
A LIF with the same name already exists. |
1966987 |
The Vserver Broadcast-Domain Home-Node and Home-Port combination is not valid. |
1376656 |
Cluster LIFs must be in the same subnet. Verify the address and netmask are set to the correct values. |
1966138 |
The same IP address may not be used for both a mgmt interface and a gateway address. |
1376963 |
Duplicate IP address |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
family |
string |
IPv4 or IPv6 |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, you must set the netmask length. The default value is 64. Output is always netmask length. |
ipspace
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
broadcast_domain
Broadcast domain UUID along with a readable name.
_links |
name |
string |
Name of the broadcast domain, scoped to its IPspace |
uuid |
string |
Broadcast domain UUID |
home_node
_links |
name |
string |
uuid |
string |
node
name |
string |
Name of node on which the port is located. |
home_port
Port UUID along with readable names. Either the UUID or both names may be supplied on input.
_links |
name |
string |
node |
uuid |
string |
node
_links |
name |
string |
uuid |
string |
port
_links |
name |
string |
node |
uuid |
string |
location
auto_revert |
boolean |
broadcast_domain |
Broadcast domain UUID along with a readable name. |
failover |
string |
Defines where an interface may failover. |
home_port |
Port UUID along with readable names. Either the UUID or both names may be supplied on input. |
is_home |
boolean |
service_policy
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
ip_interface
_links |
enabled |
boolean |
ip |
IP information |
ipspace |
location |
name |
string |
Interface name |
scope |
string |
service_policy |
services |
array[string] |
state |
string |
svm |
uuid |
string |
vip |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
