REST API reference
Creates an fpolicy policy configuration for the specified svm to create an fpolicy policy, you must specify the policy scope and the fpolicy events to be monitored
  • an fpolicy engine is an optional field whose default value is set to native a native engine can be used to simply block the file access based on the file extensions specified in the policy scope
  • to enable a policy, the policy priority must be specified if the priority is not specified, the policy is created but it is not enabled
  • the "mandatory" field, if set to true, blocks the file access when the primary or secondary fpolicy servers are down # required properties
  • svmuuid - existing svm in which to create the fpolicy policy
  • events - name of the events to monitior
  • name - name of the fpolicy policy
  • scope - scope of the policy can be limited to exports, volumes, shares or file extensions
  • priority- priority of the policy (ranging from 1 to 10) # default property values
  • mandatory - true
  • engine - native # related ontap commands
  • fpolicy policy scope create
  • fpolicy policy create
  • fpolicy enable # learn more
  • [doc /protocols/fpolicy/{svmuuid}/policies](#docs-nas-protocols_fpolicy_{svmuuid}_policies)
POST /protocols/fpolicy/{svm.uuid}/policies
Creates an FPolicy policy configuration for the specified SVM. To create an FPolicy policy, you must specify the policy scope and the FPolicy events to be monitored.
Important notes:
  • A single policy can monitor multiple events.
  • An FPolicy engine is an optional field whose default value is set to native. A native engine can be used to simply block the file access based on the file extensions specified in the policy scope.
  • To enable a policy, the policy priority must be specified. If the priority is not specified, the policy is created but it is not enabled.
  • The "mandatory" field, if set to true, blocks the file access when the primary or secondary FPolicy servers are down.
Required properties
  • svm.uuid - Existing SVM in which to create the FPolicy policy.
  • events - Name of the events to monitior.
  • name - Name of the FPolicy policy.
  • scope - Scope of the policy. Can be limited to exports, volumes, shares or file extensions.
  • priority- Priority of the policy (ranging from 1 to 10).
Default property values
  • mandatory - true
  • engine - native
  • fpolicy enable
svm.uuid
string
path
True
Request Body
Name Type Description
engine
fpolicy_engine_reference
FPolicy external engine
events
array[fpolicy_event_reference]
mandatory
boolean
Specifies what action to take on a file access event in a case when all primary and secondary servers are down or no response is received from the FPolicy servers within a given timeout period. When this parameter is set to true, file access events will be denied under these circumstances.
name
string
Specifies the name of the policy.
priority
integer
Specifies the priority that is assigned to this policy.
scope
scope
Example request
  "enabled": null,
  "engine": {
        "href": "/api/resourcelink"
    "name": "string"
  "events": [
    "event_nfs_close",
    "event_open"
  "name": "fp_policy_1",
  "scope": {
    "exclude_export_policies": [
      "string"
    "exclude_extension": [
      "string"
    "exclude_shares": [
      "string"
    "exclude_volumes": [
      "vol1",
      "vol_svm1",
    "include_export_policies": [
      "string"
    "include_extension": [
      "string"
    "include_shares": [
      "sh1",
      "share_cifs"
    "include_volumes": [
      "vol1",
      "vol_svm1"
Status: 201, Created
_links
_links
num_records
integer
Number of Records
records
array[fpolicy_policy]
    "next": {
  "records": [
      "enabled": null,
      "engine": {
        "name": "string"
      "events": [
        "event_nfs_close",
        "event_open"
      "scope": {
          "string"
          "string"
        "exclude_shares": [
          "string"
          "vol1",
          "vol_svm1",
          "string"
          "string"
        "include_shares": [
          "sh1",
          "share_cifs"
          "vol1",
          "vol_svm1"
Status: Default
ONTAP Error Response Codes
Error Code Description
9765027
FPolicy creation is successful but it cannot be enabled as the priority is already in use by another policy
9764898
An FPolicy policy cannot be created without defining its scope
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
_links
_links
name
string
The name of the FPolicy external engine.
FPolicy events
_links
_links
name
string
scope
array[string]
exclude_extension
array[string]
exclude_shares
array[string]
exclude_volumes
array[string]
array[string]
include_extension
array[string]
include_shares
array[string]
include_volumes
array[string]
fpolicy_policy
engine
events
mandatory
boolean
name
string
priority
integer
scope
scope
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
