Create the NFS configuration for an SVM
POST /protocols/nfs/services
Creates an NFS configuration for an SVM.
Required properties
svm.uuidorsvm.name- Existing SVM for which to create the NFS configuration.
Default property values
If not specified in POST, the following default property values are assigned:
enabled- true -
state- online -
transport.udp_enabled- true -
transport.tcp_enabled- true -
protocol.v3_enabled- true -
protocol.v4_id_domain- defaultv4iddomain.com -
protocol.v4_enabled- false -
protocol.v41_enabled- false -
protocol.v40_features.acl_enabled- false -
protocol.v40_features.read_delegation_enabled- false -
protocol.v40_features.write_delegation_enabled- false -
protocol.v41_features.acl_enabled- false -
protocol.v41_features.read_delegation_enabled- false -
protocol.v41_features.write_delegation_enabled- false -
protocol.v41_features.pnfs_enabled- false -
vstorage_enabled- false
Related ONTAP commands
vserver nfs create
Learn more
Request Body
| Name | Type | Description |
_links |
enabled |
boolean |
Specifies if the NFS service is administratively enabled. |
protocol |
state |
string |
Specifies the state of the NFS service on the SVM. The following values are supported: * online - NFS server is ready to accept client requests. * offline - NFS server is not ready to accept client requests. |
svm |
transport |
vstorage_enabled |
boolean |
Specifies whether VMware vstorage feature is enabled. |
Example request
"href": "/api/resourcelink"
"protocol": {
"v4_id_domain": "string"
"state": "string",
"svm": {
"name": "svm1",
Status: 201, Created
_links |
num_records |
integer |
Number of NFS Server Records |
records |
array[nfs_service] |
"next": {
"records": [
"protocol": {
"state": "string",
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
3276916 |
Vserver is not running |
3276994 |
Kerberos must be disabled on all LIFs on Vserver before adding or removing AES encryption. Disable Kerberos on the LIF and try again |
3277038 |
Cannot enable \"showmount\" feature because it requires an effective cluster version of Data ONTAP 8.3.0 or later |
3277049 |
Cannot enable \"showmount\" feature on ID-Discard Vserver. Ensure that the Vserver is initialized and retry the command |
3277052 |
NFSv4.x access to transitioned volumes in this Vserver could trigger conversion of non-Unicode directories to Unicode, which might impact data-serving performance. Before enabling NFSv4.x for this Vserver, refer to the Data and Configuration Transition Guide |
3277069 |
Cannot disable TCP because the SnapDiff RPC server is in the \"on\" state |
3277089 |
Attempting to create an NFS server using 64-bits for NFSv3 FSIDs and File IDs on Vserver. Older client software might not work with 64-bit identifiers |
3277099 |
Domain name contains invalid characters or it is too short. Allowed characters are: alphabetical characters (A-Za-z), numeric characters (0-9), minus sign (-), and the period (.). The first character must be alphabetical or numeric, last character must not be a minus sign or a period. Minimum supported length: 2 characters, maximum of 256 characters |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
v40_features
acl_enabled |
boolean |
Specifies whether NFSv4.0 ACLs is enabled. |
read_delegation_enabled |
boolean |
Specifies whether NFSv4.0 Read Delegation is enabled. |
write_delegation_enabled |
boolean |
Specifies whether NFSv4.0 Write Delegation is enabled. |
v41_features
acl_enabled |
boolean |
Specifies whether NFSv4.1 ACLs is enabled. |
pnfs_enabled |
boolean |
Specifies whether NFSv4.1 Parallel NFS is enabled. |
boolean |
Specifies whether NFSv4.1 Read Delegation is enabled. |
boolean |
Specifies whether NFSv4.1 Write Delegation is enabled. |
protocol
v3_enabled |
boolean |
Specifies whether NFSv3 protocol is enabled. |
v40_enabled |
boolean |
Specifies whether NFSv4.0 protocol is enabled. |
v40_features |
v41_enabled |
boolean |
Specifies whether NFSv4.1 protocol is enabled. |
v41_features |
v4_id_domain |
string |
Specifies the domain portion of the string form of user and group names as defined by the NFSv4 protocol. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
transport
tcp_enabled |
boolean |
Specifies whether TCP transports are enabled on the server. |
udp_enabled |
boolean |
Specifies whether UDP transports are enabled on the server. |
nfs_service
_links |
enabled |
boolean |
protocol |
state |
string |
svm |
transport |
vstorage_enabled |
boolean |
_links
next |
self |
nfs_service
_links |
enabled |
boolean |
protocol |
state |
string |
svm |
transport |
vstorage_enabled |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
