REST API reference
Creates an nvme service
  • vserver nvme create # learn more
  • [doc /protocols/nvme/services](#docs-nvme-protocols_nvme_services)
POST /protocols/nvme/services
Creates an NVMe service.
Required properties
  • svm.uuid or svm.name - The existing SVM in which to create the NVMe service.
Request Body
Name Type Description
_links
_links
enabled
boolean
The administrative state of the NVMe service. The NVMe service can be disabled to block all NVMe connectivity to the SVM.
This is optional in POST and PATCH. The default setting is true (enabled) in POST.
svm
svm
Example request
      "href": "/api/resourcelink"
  "svm": {
    "name": "svm1",
Status: 201, Created
_links
_links
num_records
integer
Number of records.
records
array[nvme_service]
    "next": {
  "records": [
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
1115127
The cluster lacks a valid NVMe license.
2621462
The supplied SVM does not exist.
2621507
NVMe is not allowed for the specified SVM.
2621706
The specified svm.uuid and svm.name do not refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
72089650
An NVMe service already exists for the specified SVM.
5374893
The SVM is stopped. The SVM must be running to create an NVMe service.
72089900
An NVMe service cannot be creating in an SVM that is configured for a SAN protocol.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
nvme_service
A Non-Volatile Memory Express (NVMe) service defines the properties of the NVMe controller target for an SVM. There can be at most one NVMe service for an SVM. An SVM's NVMe service must be created before NVMe host initiators can connect to the SVM.
An NVMe service is identified by the UUID of its SVM.
_links
_links
enabled
boolean
svm
svm
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
