REST API reference
Creates an fc protocol service
  • vserver fcp create # learn more
  • [doc /protocols/san/fcp/services](#docs-san-protocols_san_fcp_services)
POST /protocols/san/fcp/services
Creates an FC Protocol service.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the FC service.
Request Body
Name Type Description
_links
_links
enabled
boolean
The administrative state of the FC Protocol service. The FC Protocol service can be disabled to block all FC Protocol connectivity to the SVM.
This is optional in POST and PATCH. The default setting is true (enabled) in POST.
svm
svm
target
target
Example request
      "href": "/api/resourcelink"
  "svm": {
    "name": "svm1",
  "target": {
    "name": "20:00:00:50:56:bb:b2:4b"
Status: 201, Created
_links
_links
num_records
integer
Number of records.
records
array[fcp_service]
    "next": {
  "records": [
      "svm": {
        "name": "svm1",
      "target": {
Status: Default
ONTAP Error Response Codes
Error Code Description
1115127
The cluster lacks a valid FCP license.
2621462
The supplied SVM does not exist.
2621706
The specified svm.uuid and svm.name do not refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
2621507
The Fibre Channel Protocol is not allowed for the specified SVM.
5374092
The Fibre Channel Procotol is not supported on the cluster hardware configuration; there are no Fibre Channel adapters.
5374893
The SVM is stopped. The SVM must be running to create a Fibre Channel Protocol service.
5374082
The Fibre Channel Protocol service already exists for the SVM.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
target
name
string
The target name of the FC Protocol service. This is generated for the SVM during POST.
The FC Protocol target name is a world wide node name (WWNN).
If required, the target name can be modified using the ONTAP command line.
  • example: 20:00:00:50:56:bb:b2:4b
  • maxLength: 128
  • minLength: 1
  • readOnly: 1
fcp_service
A Fibre Channel (FC) Protocol service defines the properties of the FC Protocol target for an SVM. There can be at most one FC Protocol service for an SVM. An SVM's FC Protocol service must be created before FC Protocol initiators can login to the SVM.
A FC Protocol service is identified by the UUID of its SVM.
_links
_links
enabled
boolean
svm
svm
target
target
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
