REST API reference
Adds one or more initiators to an initiator group
  • lun igroup add # learn more
  • [doc /protocols/san/igroups](#docs-san-protocols_san_igroups)
POST /protocols/san/igroups/{igroup.uuid}/initiators
Adds one or more initiators to an initiator group.
Required properties
  • name or records.name - Initiator name(s) to add to the initiator group.
  • lun igroup add
igroup.uuid
string
path
True
The unique identifier of the initiator group.
Request Body
Name Type Description
_links
_links
igroup
igroup
The initiator group in which the initiator is found.
Note that this does not mean that the initiator cannot also be found in other initiator groups.
name
string
The FC WWPN, iSCSI IQN, or iSCSI EUI that identifies the host initiator. Valid in POST only and not allowed when the records property is used.
An FC WWPN consist of 16 hexadecimal digits grouped as 8 pairs separated by colons. The format for an iSCSI IQN is iqn.yyyy-mm.reverse_domain_name:any. The iSCSI EUI format consists of the eui. prefix followed by 16 hexadecimal characters.
records
array[records]
An array of initiators specified to add multiple initiators to an initiator group in a single API call. Valid in POST only and not allowed when the name property is used.
Example request
      "href": "/api/resourcelink"
  "igroup": {
  "name": "iqn.1998-01.com.corp.iscsi:name1",
  "records": [
      "igroup": {
Status: 201, Created
_links
_links
num_records
integer
Number of records.
records
array[igroup_initiator]
    "next": {
  "records": [
      "igroup": {
      "records": [
          "igroup": {
Status: Default
ONTAP Error Response Codes
Error Code Description
5374033
Initiators must be supplied.
5374038
An invalid Fibre Channel WWPN was supplied.
5374039
An invalid iSCSI initiator name was supplied.
5374852
The initiator group specified in the URI does not exist.
5374853
You can add initiators to an initiator group using the records property, or the name> property, but you cannot use both in the same request.
5374854
Only records property elements must be populated with only the name property values.
5374035
A supplied initiator is already in the initiator group.
5373992
A supplied initiator name was too long to be valid.
5373993
A supplied initiator name did not match any valid format.
5373978
A supplied initiator name looks like an iSCSI EUI initiator, but the format is invalid.
5373977
A supplied initiator name looks like an iSCSI EUI initiator, but the length is invalid.
5373971
A supplied initiator name looks like an iSCSI IQN initiator, but the date portion is invalid.
5373972
A supplied initiator name looks like an iSCSI IQN initiator, but the naming authority portion is invalid.
5373969
A supplied initiator name looks like an iSCSI IQN initiator, but the portions after the prefix are missing.
5374734
An initiator is already in another initiator group with a conflicting operating system type.
1254193
Adding an initiator would cause the initiator to mapped to the same LUN more than once.
1254324
Adding an initiator would cause the initiator to have the same logical unit identifier for multiple LUN maps.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
igroup
_links
_links
uuid
string
records
_links
_links
igroup
igroup
name
string
igroup_initiator
_links
_links
igroup
igroup
name
string
records
array[records]
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
