Define the remote syslog or splunk server information
POST /security/audit/destinations
Configures remote syslog/splunk server information.
Required properties
All of the following fields are required for creating a remote syslog/splunk destination
address
Optional properties
All of the following fields are optional for creating a remote syslog/splunk destination
port -
protocol -
facility -
verify_server(Can only be "true" when protocol is "tcp_encrypted")
Learn more
force |
boolean |
query |
False |
Skip the Connectivity Test
Request Body
| Name | Type | Description |
address |
string |
Destination syslog|splunk host to forward audit records to. This can be an IP address (IPv4|IPv6) or a hostname. |
facility |
string |
This is the standard Syslog Facility value that is used when sending audit records to a remote server. |
port |
integer |
Destination Port. The default port depends on the protocol chosen: For un-encrypted destinations the default port is 514. For encrypted destinations the default port is 6514. |
protocol |
string |
Log forwarding protocol |
verify_server |
boolean |
This is only applicable when the protocol is tcp_encrypted. This controls whether the remote server's certificate is validated. Setting "verify_server" to "true" will enforce validation of remote server's certificate. Setting "verify_server" to "false" will not enforce validation of remote server's certificate. |
Example request
"address": "string",
"facility": "string",
"protocol": "string"
Status: 202, Accepted
_links |
num_records |
integer |
Number of records |
records |
array[security_audit_log_forward] |
"next": {
"href": "/api/resourcelink"
"records": [
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
15661 |
The object specified could not be found |
13114 |
Internal error |
13115 |
Invalid input |
4522285 |
Server verification cannot be enabled because it requires a protocol with encryption. Encryption can be selected using the protocol field. |
9240603 |
Cannot ping destination host. Verify connectivity to desired host or skip the connectivity check with the -force parameter. |
327698 |
Failed to create rpc client to destination host |
9240609 |
Cannot connect to destination host. |
9240604 |
Cannot resolve the destination host. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
address |
string |
facility |
string |
port |
integer |
protocol |
string |
verify_server |
boolean |
href |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
