Add primary key servers to an external key manager
POST /security/key-managers/{uuid}/key-servers
Adds key servers to a configured external key manager.
Required properties
uuid- UUID of the external key manager. -
server- Key server name.
Related ONTAP commands
security key-manager external add-servers
uuid |
string |
path |
True |
External key manager UUID |
Request Body
| Name | Type | Description |
_links |
password |
string |
Password credentials for connecting with the key server. This is not audited. |
records |
array[records] |
An array of key servers specified to add multiple key servers to a key manager in a single API call. Valid in POST only and not valid if |
server |
string |
External key server for key management. If no port is provided, a default port of 5696 is used. Not valid in POST if |
Example request
"href": "/api/resourcelink"
"password": "password",
"records": [
"server": "keyserver1.com:5698"
Status: 201, Created
_links |
num_records |
integer |
Number of records |
records |
array[key_server] |
"next": {
"records": [
"records": [
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536822 |
Multitenant key management is not supported in the current cluster version. |
65536828 |
External key management is not enabled for the SVM. |
65536824 |
Multitenant key management is not supported in MetroCluster configurations. |
65536038 |
A maximum of 4 active key servers are allowed. |
65536871 |
Duplicate key management servers exist. |
65536834 |
Failed to get existing key-server details for the SVM. |
65536870 |
Key management servers already configured. |
65536821 |
Certificate is not installed. |
65536852 |
Failed to query supported KMIP protocol versions. |
66060338 |
Failed to establish secure connection for a key management server due to incorrect server_ca certificates. |
66060339 |
Failed to establish secure connection for a key management server due to incorrect client certificates. |
66060340 |
Failed to establish secure connection for a key management server due to Cryptsoft error. |
66060341 |
Failed to establish secure connection for a key management server due to network configuration issues. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
records
_links |
password |
string |
server |
string |
key_server
_links |
password |
string |
records |
array[records] |
server |
string |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
