REST API reference
Creates a snapmirror policy the parameter "identity_preservation" is applicable to only snapmirror relationships with svm endpoints and it indicates which configuration of the source svm is replicated to the destination svm</br>
  • exclude_network_config - indicates that the source svm configuration other than network configuration is replicated to the destination svm endpoint
  • exclude_network_and_protocol_config - indicates that the source svm configuration is not replicated to the destination svm endpoint<br/> # important note
  • the property "identity_preservation" is applicable to only snapmirror relationships with svm endpoints and it indicates which configuration of the source svm is replicated to the destination svm
  • the properties "identity_preservation", "retention" and "transfer_schedule" are not applicable for "sync" type policies
  • the property "sync_common_snapshot_schedule" is not applicabe for an "async" type policy
  • the property "retentioncount" specifies the maximum number of snapshot copies that are retained on the snapmirror destination volume
  • when the property "retentionlabel" is specified, the snapshot copies that have a snapmirror label matching this property is transferred to the snapmirror destination
  • when the property "retentioncreation_schedule" is specified, snapshot copies are directly created on the snapmirror destination the snapshot copies created have the same content as the latest snapshot copy already present on the snapmirror destination # required properties
    • name - name of the new snapmirror policy # recommended optional properties
    • svmname or svmuuid - name or uuid of the svm that owns the snapmirror policy # default property values if not specified in post, the following default property values are assigned:
    • type - async
    • sync_type - sync (when type is sync)
    • network_compression_enabled - false
    • throttle - 0
    • identity_preservation - exclude_network_and_protocol_config # related ontap commands
    • snapmirror policy create # examples creating a snapmirror policy of type "sync" <br/> ` post "/api/snapmirror/policies/" {"name": "policy1", "svmname": "vs0", "type": "sync", "sync_type": "sync"} ` <br/> creating a snapmirror policy of type "async" with retention values <br/> ` post "/api/snapmirror/policies" {"name": "policy_ret", "svm": {"name": "vs1"}, "retention": {"label": ["smcreate"], "count": ["2"], "creation_schedule": ["weekly"]}} ` <br/> creating a snapmirror policy of type "async" ` post "/api/snapmirror/policies" {"name": "newpolicy", "svm":{"name" : "vs1"}, "type": "async"} ` <br/> # learn more
    • [doc /snapmirror/policies](#docs-snapmirror-snapmirror_policies)
POST /snapmirror/policies
Creates a SnapMirror policy. The parameter "identity_preservation" is applicable to only SnapMirror relationships with SVM endpoints and it indicates which configuration of the source SVM is replicated to the destination SVM.
It takes the following values:
  • full - indicates that the source SVM configuration is replicated to the destination SVM endpoint.
  • exclude_network_config - indicates that the source SVM configuration other than network configuration is replicated to the destination SVM endpoint.
  • exclude_network_and_protocol_config - indicates that the source SVM configuration is not replicated to the destination SVM endpoint.
Important note
  • The property "identity_preservation" is applicable to only SnapMirror relationships with SVM endpoints and it indicates which configuration of the source SVM is replicated to the destination SVM.
  • The properties "identity_preservation", "retention" and "transfer_schedule" are not applicable for "sync" type policies.
  • The property "sync_common_snapshot_schedule" is not applicabe for an "async" type policy.
  • The property "retention.count" specifies the maximum number of Snapshot copies that are retained on the SnapMirror destination volume.
  • When the property "retention.label" is specified, the Snapshot copies that have a SnapMirror label matching this property is transferred to the SnapMirror destination.
  • When the property "retention.creation_schedule" is specified, Snapshot copies are directly created on the SnapMirror destination. The Snapshot copies created have the same content as the latest Snapshot copy already present on the SnapMirror destination.
Required properties
  • name - Name of the new SnapMirror policy.
  • svm.name or svm.uuid - Name or UUID of the SVM that owns the SnapMirror policy.
Default property values
If not specified in POST, the following default property values are assigned:
  • type - async
  • throttle - 0
Creating a SnapMirror policy of type "sync"
 POST "/api/snapmirror/policies/" '{"name": "policy1", "svm.name": "VS0", "type": "sync", "sync_type": "sync"}'
Creating a SnapMirror policy of type "async" with retention values
 POST "/api/snapmirror/policies" '{"name": "policy_ret", "svm": {"name": "vs1"}, "retention": {"label": ["smcreate"], "count": ["2"], "creation_schedule": ["weekly"]}}'
 POST "/api/snapmirror/policies" '{"name": "newPolicy", "svm":{"name" : "vs1"}, "type": "async"}'
return_timeout
integer
query
False
Request Body
Name Type Description
_links
_links
comment
string
Comment associated with the policy.
string
Specifies which configuration of the source SVM is replicated to destination. This field is applicable only for SVM data protection and async policies.
name
string
boolean
Specifies whether network compression is enabled for transfers. This is applicable only to async policies.
retention
array[snapmirror_policy_rule]
Policy on Snapshot copy retention. This is applicable only to async policies.
scope
string
Set to "svm" for policies owned by an SVM, otherwise set to "cluster".
svm
svm
Schedule used to create common Snapshot copies for synchronous relationships.
sync_type
string
throttle
integer
Throttle in KB/s. Default to unlimited.
transfer_schedule
transfer_schedule
The schedule used to update asynchronous relationships.
type
string
uuid
string
Example request
      "href": "/api/resourcelink"
  "comment": "string",
  "identity_preservation": "string",
  "name": "MirrorAndVault",
  "retention": [
      "count": 7,
      "creation_schedule": {
        "name": "weekly",
      "label": "hourly",
      "prefix": "string"
  "scope": "string",
  "svm": {
    "name": "svm1",
  "sync_common_snapshot_schedule": {
    "name": "weekly",
  "sync_type": "string",
  "throttle": 0,
  "transfer_schedule": {
    "name": "weekly",
  "type": "string",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response codes
Error code Description
13303850
Invalid input parameter
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
creation_schedule
Schedule used to create Snapshot copies on the destination for long term retention.
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
SnapMirror policy rule for retention.
count
integer
Number of Snapshot copies to be kept for retention.
creation_schedule
creation_schedule
label
string
Snapshot copy label
prefix
string
Specifies the prefix for the Snapshot copy name to be created as per the schedule. If no value is specified, then the label is used as the prefix.
svm
_links
_links
name
string
The name of the SVM.
uuid
string
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
transfer_schedule
_links
_links
name
string
Job schedule name
uuid
string
Job schedule UUID
snapmirror_policy
SnapMirror policy information
_links
_links
comment
string
string
name
string
boolean
retention
scope
string
svm
svm
sync_type
string
throttle
integer
transfer_schedule
transfer_schedule
type
string
uuid
string
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
