REST API reference
Starts a snapmirror transfer operation this api initiates a restore operation if the snapmirror relationship is of type "restore" otherwise, it intiates a snapmirror "initialize" operation or "update" operation based on the current snapmirror state
  • snapmirror update
  • snapmirror initialize
  • snapmirror restore # examples the following examples show how to perform snapmirror "initialize", "update", and "restore" operations <br/> performing a snapmirror initialize or update <br/> ` post "/api/snapmirror/relationships/e4e7e130-0279-11e9-b566-0050568e9909/transfers" {} ` <br/> performing a snapmirror restore transfer <br/> ` post "/api/snapmirror/relationships/c8c62a90-0fef-11e9-b09e-0050568e7067/transfers" {"source-snapshot": "src", "files": {"source_path": ["/a1txt0"], "destination_path": ["/a1-renamedtxt0"]}} ` <br/> # learn more
  • [doc /snapmirror/relationships/{relationshipuuid}/transfers](#docs-snapmirror-snapmirror_relationships_{relationshipuuid}_transfers)
POST /snapmirror/relationships/{relationship.uuid}/transfers
Starts a SnapMirror transfer operation. This API initiates a restore operation if the SnapMirror relationship is of type "restore". Otherwise, it intiates a SnapMirror "initialize" operation or "update" operation based on the current SnapMirror state.
Default property values
  • storage_efficiency_enabled - true
  • snapmirror update
The following examples show how to perform SnapMirror "initialize", "update", and "restore" operations.
Performing a SnapMirror initialize or update
 POST "/api/snapmirror/relationships/e4e7e130-0279-11e9-b566-0050568e9909/transfers" '{}'
Performing a SnapMirror restore transfer
 POST "/api/snapmirror/relationships/c8c62a90-0fef-11e9-b09e-0050568e7067/transfers" '{"source-snapshot": "src", "files": {"source_path": ["/a1.txt.0"], "destination_path": ["/a1-renamed.txt.0"]}}'
return_timeout
integer
query
False
relationship.uuid
string
path
True
Relationship UUID
Request Body
Name Type Description
_links
_links
bytes_transferred
integer
Bytes transferred
checkpoint_size
integer
Amount of data transferred in bytes as recorded in the restart checkpoint.
files
array[files]
This is supported for transfer of restore relationship only. This specifies the list of files or LUNs to be restored. Can contain up to eight files or LUNs.
relationship
relationship
snapshot
string
Name of Snapshot copy being transferred.
source_snapshot
string
Specifies the Snapshot copy on the source to be transferred to the destination.
boolean
This is supported for transfer of restore relationship only. Set this field to 'false' to turn off storage efficiency for data transferred over the wire and written to the destination.
uuid
string
Example request
      "href": "/api/resourcelink"
  "bytes_transferred": 0,
  "checkpoint_size": 0,
  "files": [
      "destination_path": "/dirb/file2",
      "source_path": "/dira/file1"
  "relationship": {
    "destination": {
      "path": "svm1:volume1",
      "svm": {
        "name": "svm1",
    "uuid": "d2d7ceea-ab52-11e8-855e-00505682a4c7"
  "snapshot": "string",
  "source_snapshot": "string",
Status: 201, Created
Status: Default
ONTAP Error Response codes
Error code Description
13303845
Restore operation failed
13303812
Initialize operation failed
13303844
Update operation failed
13303846
Empty source path file list
13303847
Invalid arguments
6620237
SnapMirror relationship database write failed
6620238
SnapMirror relationship database read failed
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
files
Specifies a file or LUN consisting of a source_path and an optional destination_path. If not specified, the destination_path is the same as the source_path.
destination_path
string
source_path
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
snapmirror_endpoint
Endpoint of a SnapMirror relationship.
path
string
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1:
  • example: svm1:volume1
  • readCreate: 1
svm
svm
relationship
destination
snapmirror_endpoint
restore
boolean
Is the relationship for restore?
uuid
string
snapmirror_transfer
Snapmirror transfer information
_links
_links
bytes_transferred
integer
Bytes transferred
checkpoint_size
integer
files
array[files]
relationship
relationship
snapshot
string
source_snapshot
string
boolean
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
