Create a SnapMirror relationship
POST /snapmirror/relationships
Creates a SnapMirror relationship. This API must be executed on the cluster containing the destination endpoint.
Required properties
source.path- Path to the source endpoint of the SnapMirror relationship. -
destination.path- Path to the destination endpoint of the SnapMirror relationship.
Recommended optional properties
policy.nameorpolicy.uuid- Policy governing the SnapMirror relationship.
Default property values
If not specified in POST, the following default property values are assigned:
policy.name- MirrorAndVault -
restore- false
Related ONTAP commands
snapmirror create
The following examples show how to create FlexVol, FlexGroup and SVM SnapMirror relationships. Note that the source SVM name should be the local name of the peer SVM.
Creating a FlexVol SnapMirror relationship of type XDP.
POST "/api/snapmirror/relationships/" '{"source": {"path": "test_vserv_src:src_vol_rw"}, "destination": { "path": "test_vserv_dst:dst_vol_rw"}}'
Creating a FlexGroup SnapMirror relationship of type XDP.
POST "/api/snapmirror/relationships/" '{"source": {"path": "test_vserv_src:source_flexgrp"}, "destination": { "path": "test_vserv_dst:dest_flexgrp"}}'
Creating a SVM SnapMirror relationship of type XDP.
POST "/api/snapmirror/relationships/" '{"source": { "path": "src_svm:"}, "destination": { "path": "dst_svm:"}}'
Creating a SnapMirror relationship in order to restore from a destination.
POST "/api/snapmirror/relationships/" '{"source": {"path": "test_vserv_src:src_vol_rw"}, "destination": { "path": "test_vserv_dst:dst_vol_rw"}, "restore": "true"}'
Learn more
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
Request Body
| Name | Type | Description |
destination |
Endpoint of a SnapMirror relationship. |
exported_snapshot |
string |
Snapshot copy exported to clients on destination. |
healthy |
boolean |
Is the relationship healthy? |
lag_time |
string |
Time since the exported Snapshot copy was created. |
policy |
Basic policy information of the relationship. |
preserve |
boolean |
Set to true on resync to preserve Snapshot copies on the destination that are newer than the latest common Snapshot copy. This field is applicable only for relationships with FlexGroup or FlexVol endpoints and when the PATCH state is "snapmirrored". |
quick_resync |
boolean |
Set to true to reduce resync time by not preserving storage efficiency. This field is applicable only for relationships with FlexVol endpoints and when the PATCH state is "snapmirrored". |
recover_after_break |
boolean |
Set to true to recover from a failed SnapMirror break operation on a FlexGroup relationship. This restores all destination FlexGroup constituents to the latest Snapshot copy, and any writes to the read-write constituents are lost. This field is applicable only for SnapMirror relationships with FlexGroup endpoints and when the PATCH state is "broken_off". |
restore |
boolean |
Set to true to create a relationship for restore. To trigger restore-transfer, use transfers POST on the restore relationship. |
restore_to_snapshot |
string |
Specifies the Snapshot copy to restore to on the destination after a break operation. This field is applicable only for SnapMirror relationships with FlexVol endpoints and when the PATCH state is "broken_off". |
source |
transfer |
Basic information on the current transfer. |
unhealthy_reason |
array[snapmirror_error] |
Reason the relationship is not healthy. It is a concatenation of up to four levels of error messages. |
uuid |
string |
Example request
"destination": {
"path": "svm1:volume1",
"svm": {
"href": "/api/resourcelink"
"name": "svm1",
"exported_snapshot": "string",
"lag_time": "PT8H35M42S",
"policy": {
"name": "MirrorAndVault",
"type": "string",
"restore_to_snapshot": "string",
"source": {
"svm": {
"name": "svm1",
"transfer": {
"state": "string",
"unhealthy_reason": [
"code": "6621444",
"message": "Failed to complete update operation on one or more item relationships.",
"parameters": []
"code": "6621445",
"message": "Group Update failed",
"parameters": []
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
13303841 |
Cross platform relationships are not allowed |
13303821 |
Invalid SnapMirror policy UUID |
13303819 |
Could not retrieve SnapMirror policy information |
13303852 |
destination.path provided does not contain \":\" |
13303853 |
Restore relationships are not supported for SVM-DR endpoints |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
snapmirror_endpoint
path |
string |
ONTAP FlexVol/FlexGroup - svm1:volume1 ONTAP SVM - svm1:
svm |
policy
_links |
name |
string |
type |
string |
uuid |
string |
transfer
_links |
bytes_transferred |
integer |
Bytes transferred. |
state |
string |
uuid |
string |
snapmirror_error
SnapMirror error
code |
integer |
Error code |
message |
string |
Error message |
parameters |
array[string] |
Parameters for the error message |
snapmirror_relationship
SnapMirror relationship information
destination |
exported_snapshot |
string |
healthy |
boolean |
lag_time |
string |
policy |
preserve |
boolean |
quick_resync |
boolean |
boolean |
restore |
boolean |
string |
source |
transfer |
unhealthy_reason |
uuid |
string |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
