Create a FlexCache volume in the cluster
POST /storage/flexcache/flexcaches
Creates a FlexCache in the cluster.
Required properties
name- Name of FlexCache volume. -
origins.volume.nameororigins.volume.uuid- Name or UUID of origin volume. -
origins.svm.name- Name of origin Vserver. -
svm.nameorsvm.uuid- Name or UUID of Vserver where FlexCache will be created.
Recommended optional properties
path- Path to mount the FlexCache volume
Default property values
If not specified in POST, the following default property values are assigned:
size- 10% of origin volume size or 1GB per constituent, whichever is greater. -
constituents_per_aggregate- 4 if aggregates.name or aggregates.uuid is used.
Related ONTAP commands
volume flexcache create
Learn more
Request Body
| Name | Type | Description |
_links |
aggregates |
array[aggregates] |
constituents_per_aggregate |
integer |
Number of FlexCache constituents per aggregate when the 'aggregates' field is mentioned. |
name |
string |
FlexCache name |
origins |
array[flexcache_relationship] |
path |
string |
The fully-qualified path in the owning SVM's namespace at which the FlexCache is mounted. The path is case insensitive and must be unique within a SVM's namespace. Path must begin with '/' and must not end with '/'. Only one FlexCache be mounted at any given junction path. |
size |
integer |
Physical size of the FlexCache. The recommended size for a FlexCache is 10% of the origin volume. The minimum FlexCache constituent size is 1GB. |
svm |
FlexCache SVM |
uuid |
string |
FlexCache UUID. Unique identifier for the FlexCache. |
Example request
"href": "/api/resourcelink"
"aggregates": [
"name": "aggr1",
"name": "vol1",
"origins": [
"cluster": {
"name": "cluster1",
"create_time": "2018-06-04 19:00:00 UTC",
"ip_address": "10.10.10.7",
"size": 0,
"state": "string",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
"path": "/user/my_fc",
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66846870 |
Either the SVM name or origin volume name is missing |
66846871 |
Constituents per aggregate are specified but aggregate name is missing |
66846872 |
More than one origin volume is specified |
66846873 |
The specified SVM UUID is incorrect for the specified SVM name |
66846874 |
The specified aggregate UUID is incorrect for the specified aggregate name |
66846875 |
The specified aggregate name does not exist |
66846876 |
The specified SVM does not exist or is not peered |
66846877 |
The specified origin SVM name is of zero length |
66846878 |
The specified SVM UUID is invalid |
66846730 |
Failed to create a FlexCache volume |
66846760 |
The specified SVM is not a data Vserver |
66846787 |
The specified aggregate is a SnapLock aggregate |
66846812 |
The specified aggregate is a Composite aggregate |
66846812 |
The specified junction path is under a FlexCache volume |
66846834 |
FlexCache encryption requires a cluster version of 9.6 or higher |
66846835 |
A volume encryption license is not found |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
aggregates
Aggregate
_links |
name |
string |
uuid |
string |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
cluster |
create_time |
string |
Creation time of the relationship. |
ip_address |
string |
Cluster managerment IP of the remote cluster. |
size |
integer |
Size of the remote volume. |
state |
string |
Volume state |
svm |
volume |
svm
FlexCache SVM
_links |
name |
string |
uuid |
string |
flexcache
Defines the cache endpoint of FlexCache.
_links |
aggregates |
array[aggregates] |
integer |
name |
string |
FlexCache name |
origins |
path |
string |
size |
integer |
svm |
FlexCache SVM |
uuid |
string |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
