Creates a qos policy
name- the name of the qos policy -
fixed*oradaptive*- either of the fixed or adaptive parameters # default property values -
if
fixed*parameters are specified, then capacityshared is set to false by default # related ontap commands -
qos policy-group create -
qos adaptive-policy-group create
learn more
doc /storage/qos/policies](#docs-storage-storage_qos_policies)
POST /storage/qos/policies
Creates a QoS policy.
Required properties
svm.uuidorsvm.name- The existing SVM owning the QoS policy. -
name- The name of the QoS policy. -
fixed.*oradaptive.*- Either of the fixed or adaptive parameters.
Default property values
If
fixed.*parameters are specified, then capacity.shared is set to false by default.
Related ONTAP commands
Learn more
return_timeout |
integer |
query |
False |
The number of seconds to allow the call to execute before returning. When doing a POST, PATCH, or DELETE operation on a single record, the default is 0 seconds. This means that if an asynchronous operation is started, the server immediately returns HTTP code 202 (Accepted) along with a link to the job. If a non-zero value is specified for POST, PATCH, or DELETE operations, ONTAP waits that length of time to see if the job completes so it can return something other than 202. |
Request Body
| Name | Type | Description |
_links |
adaptive |
Adaptive QoS policy-groups define measurable service level objectives (SLOs) that adjust based on the storage object used space and the storage object allocated space. |
fixed |
QoS policy-groups define a fixed service level objective (SLO) for a storage object. |
name |
string |
Name of the QoS policy. |
object_count |
integer |
Number of objects attached to this policy. |
svm |
uuid |
string |
Example request
"href": "/api/resourcelink"
"name": "extreme",
"object_count": 0,
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
8454277 |
The name specified for creating an adaptive QoS policy conflicts with an existing fixed QoS policy name. |
8454278 |
The name specified for creating a fixed QoS policy conflicts with an existing adaptive QoS policy name. |
8454154 |
The name specified for creating conflicts with an existing QoS policy name. |
8454147 |
The maximum limit for QoS policies has been reached. |
8454273 |
Invalid value for an adaptive field. Value should be non-zero. |
8454260 |
Invalid value for maximum and minimum fields. Valid values for max_throughput_iops and max_throughput_mbps combination is for the ratio of max_throughput_mbps and max_throughput_iops to be within 1 to 4096. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
adaptive
absolute_min_iops |
integer |
Specifies the absolute minimum IOPS that is used as an override when the expected_iops is less than this value. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
expected_iops |
integer |
Expected IOPS. Specifies the minimum expected IOPS per TB allocated based on the storage object allocated size. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
peak_iops |
integer |
Peak IOPS. Specifies the maximum possible IOPS per TB allocated based on the storage object allocated size or the storage object used size. |
fixed
capacity_shared |
boolean |
Specifies whether the capacities are shared across all objects that use this QoS policy-group. Default is false. |
max_throughput_iops |
integer |
Maximum throughput defined by this policy. It is specified in terms of IOPS. 0 means no maximum throughput is enforced. |
max_throughput_mbps |
integer |
Maximum throughput defined by this policy. It is specified in terms of Mbps. 0 means no maximum throughput is enforced. |
min_throughput_iops |
integer |
Minimum throughput defined by this policy. It is specified in terms of IOPS. 0 means no minimum throughput is enforced. These floors are not guaranteed on non-AFF platforms or when FabricPool tiering policies are set. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
qos_policy
_links |
adaptive |
fixed |
name |
string |
object_count |
integer |
svm |
uuid |
string |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
