Create a qtree in a FlexVol or FlexGroup volume
POST /storage/qtrees
Creates a qtree in a FlexVol or a FlexGroup volume.
After a qtree is created, the new qtree is assigned an identifier. This identifier is obtained using a qtree GET request. This identifier is used in the API path for the qtree PATCH and DELETE operations.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the qtree. -
volume.uuidorvolume.name- Existing volume in which to create the qtree. -
name- Name for the qtree.
Recommended optional properties
If not specified in POST, the values are inherited from the volume.
security_style- Security style for the qtree. -
unix_permissions- UNIX permissions for the qtree. -
export_policy.name or export_policy.id- Export policy of the SVM for the qtree.
Related ONTAP commands
qtree create
Learn more
Request Body
| Name | Type | Description |
_links |
export_policy |
Export Policy |
id |
integer |
The identifier for the qtree, unique within the qtree's volume. |
name |
string |
The name of the qtree. Required in POST; optional in PATCH. |
path |
string |
Client visible path to the qtree. This field is not available if the volume does not have a junction-path configured. Not valid in POST or PATCH. |
security_style |
string |
Security style. Valid in POST or PATCH. |
svm |
Required in POST |
unix_permissions |
integer |
The UNIX permissions for the qtree. Valid in POST or PATCH. |
volume |
Required in POST |
Example request
"href": "/api/resourcelink"
"export_policy": {
"id": 100,
"name": "default"
"id": 1,
"name": "string",
"path": "/volume3/qtree1",
"security_style": "string",
"svm": {
"name": "svm1",
"unix_permissions": 493,
"volume": {
"name": "volume1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
The specified SVM does not exist. |
917927 |
The specified volume was not found. |
2621706 |
The specified |
918236 |
The specified |
2621707 |
No SVM was specified. Either |
918232 |
Either |
5242953 |
Qtree name must be provided. |
5242952 |
Export Policy ID specified is invalid. |
5242951 |
Export Policy supplied does not belong to the specified Export Policy ID. |
5242886 |
Failed to create qtree. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
export_policy
Export Policy
_links |
id |
integer |
name |
string |
svm
Required in POST
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
Required in POST
_links |
name |
string |
The name of the volume. |
uuid |
string |
qtree
A qtree is a directory at the top level of a volume to which a custom export policy (for fine-grained access control) and a quota rule can be applied, if required.
_links |
export_policy |
Export Policy |
id |
integer |
name |
string |
path |
string |
security_style |
string |
svm |
Required in POST |
unix_permissions |
integer |
volume |
Required in POST |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
