Creates a snapshot copy policy
name- name for the snapshot copy policy -
copiesschedule- schedule at which snapshot copies are captured on the volume -
copiescount- number of snapshot copies to maintain for this schedule # recommended optional properties -
copiesprefix- prefix to use when creating snapshot copies at regular intervals # default property values if not specified in post, the following default property values are assigned: -
enabled- true -
copiesprefix- value ofschedulename# related ontap commands -
snapshot policy create# learn more -
doc /storage/snapshot-policies](#docs-storage-storage_snapshot-policies)
POST /storage/snapshot-policies
Creates a Snapshot copy policy.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the Snapshot copy policy. -
name- Name for the Snapshot copy policy. -
copies.schedule- Schedule at which Snapshot copies are captured on the volume. -
copies.count- Number of Snapshot copies to maintain for this schedule.
Recommended optional properties
copies.prefix- Prefix to use when creating Snapshot copies at regular intervals.
Default property values
If not specified in POST, the following default property values are assigned:
enabled- true -
copies.prefix- Value ofschedule.name
Related ONTAP commands
Learn more
Request Body
| Name | Type | Description |
_links |
comment |
string |
A comment associated with the Snapshot copy policy. |
copies |
array[copies] |
enabled |
boolean |
Is the Snapshot copy policy enabled? |
name |
string |
Name of the Snapshot copy policy. |
scope |
string |
Set to "svm" when the request is on a data SVM, otherwise set to "cluster". |
svm |
uuid |
string |
Example request
"href": "/api/resourcelink"
"comment": "string",
"copies": [
"prefix": "string",
"schedule": {
"name": "hourly"
"snapmirror_label": "string"
"enabled": 1,
"name": "default",
"scope": "string",
"svm": {
"name": "svm1",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1638407 |
When adding schedule to a Snapshot copy policy, the count for that schedule must be specified. |
1638408 |
When adding schedule to a Snapshot copy policy, the schedule name must be specified. |
1638413 |
Schedule not found. |
1638417 |
Specified policy name is invalid. |
1638451 |
This operation would result in total Snapshot copy count for the policy to exceed maximum supported count. |
1638508 |
Another schedule has the same prefix within this policy. |
1638526 |
This operation is not supported on a node Vserver. |
1638527 |
Policy name already exists. |
1638528 |
This operation is not supported in a mixed-version cluster. |
1638531 |
This operation is not supported because specified policy is owned by the cluster admin. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
schedule
name |
string |
Schedule at which Snapshot copies are captured on the volume. Some common schedules already defined in the system are hourly, daily, weekly, at 15 minute intervals, and at 5 minute intervals. Snapshot copy policies with custom schedules can be referenced. |
copies
count |
integer |
The number of Snapshot copies to maintain for this schedule. |
prefix |
string |
The prefix to use while creating Snapshot copies at regular intervals. |
schedule |
snapmirror_label |
string |
Label for SnapMirror operations |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
snapshot_policy
The Snapshot copy policy object is associated with a read-write volume used to create and delete Snapshot copies at regular intervals.
_links |
comment |
string |
copies |
array[copies] |
enabled |
boolean |
name |
string |
scope |
string |
svm |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
