Create an SVM peer permission
POST /svm/peer-permissions
Creates an SVM peer permission.
Required properties
svm.nameorsvm.uuid- SVM name -
cluster_peer.uuidorcluster_peer.name- Peer cluster name or peer cluster UUID -
applications- Peering applications
Related ONTAP commands
vserver peer permission create
The following examples show how to create SVM peer permissions.
Creates an SVM peer permission entry with the local SVM and cluster peer names
 POST "/api/svm/peer-permissions" '{"cluster_peer":{"name":"cluster2"}, "svm":{"name":"VS1"}, "applications":["snapmirror"]}'
Creates an SVM peer permission entry with the local SVM and cluster peer UUID
 POST "/api/svm/peer-permissions" '{"cluster_peer":{"uuid":"d3268a74-ee76-11e8-a9bb-005056ac6dc9"}, "svm":{"uuid":"8f467b93-f2f1-11e8-9027-005056ac81fc"}, "applications":["snapmirror"]}'
Creates an SVM peer permission entry with all SVMs and the cluster peer name
 POST "/api/svm/peer-permissions" '{"cluster_peer":{"name":"cluster2"}, "svm":{"name":"*"}, "applications":["snapmirror"]}'
Learn more
Request Body
| Name | Type | Description |
_links  |
applications  |
array[string]  |
A list of applications for an SVM peer relation.  |
cluster_peer  |
Peer cluster details  |
svm  |
Local SVM permitted for peer relation. To create peer permissions for all SVMs, specify the SVM name as "*".  |
Example request
      "href": "/api/resourcelink"
  "applications": [
    "snapmirror",
    "flexcache"
  "cluster_peer": {
    "name": "cluster2",
    "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
  "svm": {
    "name": "svm1",
Status: 201, Created
_links  |
applications  |
array[string]  |
cluster_peer  |
svm  |
  "applications": [
    "snapmirror",
    "flexcache"
  "cluster_peer": {
    "name": "cluster2",
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345572  |
{field} is a required field.  |
26345573  |
Failed to find the SVM or volume UUID with name.  |
26345574  |
Failed to find the SVM or volume name with UUID.  |
26345575  |
The specified peer cluster name and peer cluster UUID do not match.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
cluster_peer
_links  |
name  |
string  |
uuid  |
string  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
svm_peer_permission
Manage SVM peer permissions.
_links  |
applications  |
array[string]  |
cluster_peer  |
svm  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
