Create a new SVM peer relationship
POST /svm/peers
Creates a new SVM peer relationship.
Important notes
The create request accepts peer SVM name as input instead of peer SVM UUID as the local cluster cannot validate peer SVM based on UUID.
The input parameter
namerefers to the local name of the peer SVM. Thepeer cluster nameparameter is optional for creating intracluster SVM peer relationships.
Required properties
svm.nameorsvm.uuid- SVM name or SVM UUID -
peer.svm.nameorpeer.svm.uuid- Peer SVM name or Peer SVM UUID -
peer.cluster.nameorpeer.cluster.uuid- Peer cluster name or peer cluster UUID -
applications- Peering applications
Related ONTAP commands
vserver peer create
Example
POST "/api/svm/peers" '{"svm":{"name":"vs1", "peer.cluster.name":"cluster2", "peer.svm.name":"VS1", "applications":["snapmirror"]}'
Learn more
Request Body
| Name | Type | Description |
_links |
applications |
array[string] |
A list of applications for an SVM peer relation. |
name |
string |
A peer SVM alias name to avoid a name conflict on the local cluster. |
peer |
Details for a peer SVM object. |
svm |
Local SVM details |
uuid |
string |
SVM peer relation UUID |
Example request
"href": "/api/resourcelink"
"applications": [
"snapmirror",
"lun_copy"
"name": "string",
"peer": {
"cluster": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"svm": {
"name": "svm1",
"svm": {
"name": "svm1",
"uuid": "string"
Status: 202, Accepted
_links |
applications |
array[string] |
name |
string |
peer |
svm |
Local SVM details |
uuid |
string |
"applications": [
"snapmirror",
"lun_copy"
"name": "string",
"peer": {
"cluster": {
"name": "cluster2",
"svm": {
"name": "svm1",
"svm": {
"name": "svm1",
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
13434889 |
Internal error. Wait and retry. |
26345575 |
The specified peer cluster name and peer cluster UUID do not match. |
26345579 |
The specified field is invalid. |
26345580 |
SVM name or SVM UUID must be provided. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
cluster
_links |
name |
string |
uuid |
string |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
peer
cluster |
svm |
svm
Local SVM details
_links |
name |
string |
uuid |
string |
svm_peer
An SVM peer relation object.
_links |
applications |
array[string] |
name |
string |
peer |
svm |
Local SVM details |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
