Protocols NVMe subsystem-controllers endpoint overview
Overview
Non-Volatile Memory Express (NVMe) subsystem controllers represent dynamic connections between hosts and a storage solution.
The NVMe subsystem controllers REST API provides information about connected hosts.
Retrieving the NVMe subsystem controllers for the entire system
# The API: GET /api/protocols/nvme/subsystem-controllers # The call: curl -X GET 'https://<mgmt-ip>/api/protocols/nvme/subsystem-controllers' -H 'accept: application/hal+json' # The response: { "records": [ { "svm": { "uuid": "f0f5b928-2593-11e9-94c4-00a0989a1c8e", "name": "symmcon_fcnvme_vserver_0", "_links": { "self": { "href": "/api/svm/svms/f0f5b928-2593-11e9-94c4-00a0989a1c8e" } } }, "subsystem": { "uuid": "14875240-2594-11e9-abde-00a098984313", "name": "symmcon_symmcon_fcnvme_vserver_0_subsystem_0", "_links": { "self": { "href": "/api/protocols/nvme/subsystems/14875240-2594-11e9-abde-00a098984313" } } }, "id": "0040h", "_links": { "self": { "href": "/api/protocols/nvme/subsystem-controllers/14875240-2594-11e9-abde-00a098984313/0040h" } } }, { "svm": { "uuid": "f0f5b928-2593-11e9-94c4-00a0989a1c8e", "name": "symmcon_fcnvme_vserver_0", "_links": { "self": { "href": "/api/svm/svms/f0f5b928-2593-11e9-94c4-00a0989a1c8e" } } }, "subsystem": { "uuid": "14875240-2594-11e9-abde-00a098984313", "name": "symmcon_symmcon_fcnvme_vserver_0_subsystem_0", "_links": { "self": { "href": "/api/protocols/nvme/subsystems/14875240-2594-11e9-abde-00a098984313" } } }, "id": "0041h", "_links": { "self": { "href": "/api/protocols/nvme/subsystem-controllers/14875240-2594-11e9-abde-00a098984313/0041h" } } }, { "svm": { "uuid": "f0f5b928-2593-11e9-94c4-00a0989a1c8e", "name": "symmcon_fcnvme_vserver_0", "_links": { "self": { "href": "/api/svm/svms/f0f5b928-2593-11e9-94c4-00a0989a1c8e" } } }, "subsystem": { "uuid": "1489d0d5-2594-11e9-94c4-00a0989a1c8e", "name": "symmcon_symmcon_fcnvme_vserver_0_subsystem_1", "_links": { "self": { "href": "/api/protocols/nvme/subsystems/1489d0d5-2594-11e9-94c4-00a0989a1c8e" } } }, "id": "0040h", "_links": { "self": { "href": "/api/protocols/nvme/subsystem-controllers/1489d0d5-2594-11e9-94c4-00a0989a1c8e/0040h" } } }, { "svm": { "uuid": "f0f5b928-2593-11e9-94c4-00a0989a1c8e", "name": "symmcon_fcnvme_vserver_0", "_links": { "self": { "href": "/api/svm/svms/f0f5b928-2593-11e9-94c4-00a0989a1c8e" } } }, "subsystem": { "uuid": "1489d0d5-2594-11e9-94c4-00a0989a1c8e", "name": "symmcon_symmcon_fcnvme_vserver_0_subsystem_1", "_links": { "self": { "href": "/api/protocols/nvme/subsystems/1489d0d5-2594-11e9-94c4-00a0989a1c8e" } } }, "id": "0041h", "_links": { "self": { "href": "/api/protocols/nvme/subsystem-controllers/1489d0d5-2594-11e9-94c4-00a0989a1c8e/0041h" } } } ], "num_records": 4, "_links": { "self": { "href": "/api/protocols/nvme/subsystem-controllers" } } }
Retrieving the NVMe subsystem controllers for a specific subsystem
# The API: GET /api/protocols/nvme/subsystem-controllers/{subsystem.uuid} # The call: curl -X GET 'https://<mgmt-ip>/api/protocols/nvme/subsystem-controllers/14875240-2594-11e9-abde-00a098984313' -H 'accept: application/hal+json' # The response: { "records": [ { "svm": { "uuid": "f0f5b928-2593-11e9-94c4-00a0989a1c8e", "name": "symmcon_fcnvme_vserver_0", "_links": { "self": { "href": "/api/svm/svms/f0f5b928-2593-11e9-94c4-00a0989a1c8e" } } }, "subsystem": { "uuid": "14875240-2594-11e9-abde-00a098984313", "name": "symmcon_symmcon_fcnvme_vserver_0_subsystem_0", "_links": { "self": { "href": "/api/protocols/nvme/subsystems/14875240-2594-11e9-abde-00a098984313" } } }, "id": "0040h", "_links": { "self": { "href": "/api/protocols/nvme/subsystem-controllers/14875240-2594-11e9-abde-00a098984313/0040h" } } }, { "svm": { "uuid": "f0f5b928-2593-11e9-94c4-00a0989a1c8e", "name": "symmcon_fcnvme_vserver_0", "_links": { "self": { "href": "/api/svm/svms/f0f5b928-2593-11e9-94c4-00a0989a1c8e" } } }, "subsystem": { "uuid": "14875240-2594-11e9-abde-00a098984313", "name": "symmcon_symmcon_fcnvme_vserver_0_subsystem_0", "_links": { "self": { "href": "/api/protocols/nvme/subsystems/14875240-2594-11e9-abde-00a098984313" } } }, "id": "0041h", "_links": { "self": { "href": "/api/protocols/nvme/subsystem-controllers/14875240-2594-11e9-abde-00a098984313/0041h" } } } ], "num_records": 2, "_links": { "self": { "href": "/api/protocols/nvme/subsystem-controllers/14875240-2594-11e9-abde-00a098984313" } } }
Retrieving a specific NVMe subsystem controller
# The API: GET /api/protocols/nvme/subsystem-controllers/{subsystem.uuid}/{id} # The call: curl -X GET 'https://<mgmt-ip>/api/protocols/nvme/subsystem-controllers/14875240-2594-11e9-abde-00a098984313/0040h' -H 'accept: application/hal+json' # The response: { "svm": { "uuid": "f0f5b928-2593-11e9-94c4-00a0989a1c8e", "name": "symmcon_fcnvme_vserver_0", "_links": { "self": { "href": "/api/svm/svms/f0f5b928-2593-11e9-94c4-00a0989a1c8e" } } }, "subsystem": { "uuid": "14875240-2594-11e9-abde-00a098984313", "name": "symmcon_symmcon_fcnvme_vserver_0_subsystem_0", "_links": { "self": { "href": "/api/protocols/nvme/subsystems/14875240-2594-11e9-abde-00a098984313" } } }, "id": "0040h", "interface": { "name": "symmcon_lif_fcnvme_symmcon_fcnvme_vserver_0_3a_0", "uuid": "fa1c5941-2593-11e9-94c4-00a0989a1c8e", "transport_address": "nn-0x200400a0989a1c8d:pn-0x200500a0989a1c8d", "_links": { "self": { "href": "/api/protocols/nvme/interfaces/fa1c5941-2593-11e9-94c4-00a0989a1c8e" } } }, "node": { "name": "ssan-8040-94a", "uuid": "ebf66f05-2590-11e9-abde-00a098984313", "_links": { "self": { "href": "/api/cluster/nodes/ebf66f05-2590-11e9-abde-00a098984313" } } }, "host": { "transport_address": "nn-0x20000090fae00806:pn-0x10000090fae00806", "nqn": "nqn.2014-08.org.nvmexpress:uuid:c2846cb1-89d2-4020-a3b0-71ce907b4eef", "id": "b8546ca6097349e5b1558dc154fc073b" }, "io_queue": { "count": 4, "depth": [ 32, 32, 32, 32 ] }, "admin_queue": { "depth": 32 }, "_links": { "self": { "href": "/api/protocols/nvme/subsystem-controllers/14875240-2594-11e9-abde-00a098984313/0040h" } } }
