Storage disks endpoint overview
Retrieving storage disk information
The storage disk GET API retrieves all of the disks in the cluster.
1) Retrieve a list of disks from the cluster
The following example shows the response with a list of disks in the cluster:
# The API:
/api/storage/disks
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/disks" -H "accept: application/hal+json"
# The response:
"records": [
"name": "1.24.4",
"href": "/api/storage/disks/1.24.4"
"name": "1.24.3",
"href": "/api/storage/disks/1.24.3"
"name": "1.24.5",
"href": "/api/storage/disks/1.24.5"
"name": "1.24.0",
"href": "/api/storage/disks/1.24.0"
"name": "1.24.2",
"href": "/api/storage/disks/1.24.2"
"name": "1.24.1",
"href": "/api/storage/disks/1.24.1"
"num_records": 6,
"href": "/api/storage/disks"
2) Retrieve a specific disk from the cluster
The following example shows the response of the requested disk. If there is no disk with the requested name, an error is returned.
# The API:
/api/storage/disks/{name}
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/disks/1.24.3" -H "accept: application/hal+json"
# The response:
"name": "1.24.3",
"uid": "50000394:0808AA88:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000",
"serial_number": "EC47PC5021SW",
"model": "X421_FAL12450A10",
"vendor": "NETAPP",
"firmware_version": "NA02",
"usable_size": 438304768000,
"rpm": 10000,
"type": "sas",
"class": "performance",
"container_type": "aggregate",
"pool": "pool0",
"state": "present",
"node": {
"uuid": "3a89ed49-8c6d-11e8-93bc-00a0985a64b6",
"name": "node-2",
"href": "/api/cluster/nodes/3a89ed49-8c6d-11e8-93bc-00a0985a64b6"
"home_node": {
"name": "node-2",
"aggregates": [
"uuid": "3fd9c345-ba91-4949-a7b1-6e2b898d74e3",
"name": "node_2_SAS_1",
"href": "/api/storage/aggregates/3fd9c345-ba91-4949-a7b1-6e2b898d74e3"
"shelf": {
"uid": "10318311901725526608",
"href": "/api/storage/shelves/10318311901725526608"
"bay": 3,
